Removing the stock pinstripes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by un par de tenis, Feb 13, 2017.
  1. Feb 13, 2017 at 10:53 AM
    un par de tenis
    un par de tenis [OP] Member
    2010 Black Tacoma Prerunner SR5 V6
    My black 2010 came with gray pinstripes on each side of it. They looked good when the truck was new, but now they're starting to fade pretty badly, and I think I'd prefer the blacked out look.
    What would be the best way to remove these? It looks like they're just stickers, would I be fine just peeling them off?
  2. Feb 13, 2017 at 10:54 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Yeah and use some goo gone to get the residue off.
  3. Feb 13, 2017 at 11:29 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I would just be concerned that the paint underneath the pin stripping is a touch darker (ghosting) as the sun hasnt touched it since it was made. Not sure if that will actually occur but worth a thought.
  4. Feb 13, 2017 at 2:30 PM
    devkurf
    devkurf Member at Large
    midwest
    You are lucky, mine are under the clear coat.
  5. Feb 13, 2017 at 2:32 PM
    devkurf
    midwest
  6. Feb 13, 2017 at 3:04 PM
    cekeel
    cekeel Enthusiast
    NC
    '08 Tacoma TRD Sport DCLB
    PC 6" w/ Kings, SCS w/ BFG A/T, ARB/All-Pro, N-Fab, Rotopax Magnaflow/AIRAID, ScanGauge/Pioneer, Wet Okole/WeatherTech
    These are amazing! Used one to take off a ton of pinstriping on an old conversion van... worked really well, and one wheel easily finished an all-day job! Just follow 3M's instructions and watch your speed... even on a horribly cared for, 15 year old van, the paint fading under the pinstripes wasn't bad, and easily polished out...
    TacomaMike37 and outlawtacoma like this.
  7. Feb 13, 2017 at 3:20 PM
    un par de tenis
    This is something I hadn't thought about. The fading is only really bad on the driver side doors, so I can live with it for now, but they are gonna come off soon.
  8. Feb 13, 2017 at 3:32 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Real amazing for removing residue left from the emblems when debadging.
  9. Feb 13, 2017 at 7:13 PM
    Pigpen
    Dan
    Northwest Montana
    OMG. Dude. Did you type something? You're my hero.
