removing the top nut?
Discussion in 'Suspension' started by Zombie Runner, Mar 9, 2009.
  1. Mar 9, 2009 at 3:37 PM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I got my bilsteins in today and i started to install the rear ones but i can tighten or loosen the top nut without the top part of the shock spinning! WTF?
    A little help here please. is there a simple trick that I'm missing?
  2. Mar 9, 2009 at 3:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sjould be able to stick an allen wrench, or an adjustable wrench on the top of the shaft to hold it from spinning
  3. Mar 9, 2009 at 3:38 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    dude, don't take off the top nut without a spring compressor
  4. Mar 9, 2009 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont be trying to remove that center nut without the springs compressed.
  5. Mar 9, 2009 at 3:42 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    the rear shock.....sorry i didnt mention it the first time
  6. Mar 9, 2009 at 4:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Rear shock should have a little hole in the top of the shaft to fit, I belive a 4mm hex head.
  7. Mar 9, 2009 at 4:03 PM
    Pat
    Pat Well-Known Member
    San Diego
    05 PreRunner Access Cab
    King Coilvers, 285 BFG A/T's, Moto Metal 951b's 17"
    I just took off the blue cover, got a par of locktight grips and locked them onto the shaft of the shock and was then able to un-do the top nut.
  8. Mar 9, 2009 at 4:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    But if you do this, you risk damageing the shock shaft. If the wrench digs into the shaft, it will no longer seal propperly, and will leak.
  9. Mar 9, 2009 at 4:16 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I had the same problem with my rear shocks! It was extremely annoying, I think I used an allen wrench on the top and some vise grips.
  10. Mar 9, 2009 at 5:14 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    take an open ended wrench and use it to hold the top of the shaft above the threads that sticks out the top plate...wont booger the end or the shaft. by time u get ot to where the nut is hitting the wrench, u can get it off w/ ur fingers
  11. Mar 9, 2009 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There are 2 different types of shock shafts. Both are very easy to remove the top nu toff off.
    First one has a hex hole in the top. They typically take a 5mm hex wrench, and useing a 17mm open wrench, you can remove the top nut.
    The other has 2 flat sides so an open wrench can be used to hold it from turning. Typically an 8mm open wrench:
    No need to grip the shock shaft with pliers, or whatever. :)
    Silversoundtaco and xxTacocaTxx like this.
  12. Mar 9, 2009 at 5:49 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    awsome, thanks for your help chris!
  13. Mar 9, 2009 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anytime, Buddy. :)
  14. Mar 10, 2009 at 12:10 AM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    Unless you are unlucky like me and the flat piece on top snaps off :eek: ...yeah vise grips on the shaft and it was off. I didn't care about the shaft since it was taking the old one off. The new bilsteins had a spot for an allen key so they went on without the same hassle.
  15. Mar 10, 2009 at 12:23 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Props to Chris.
  16. Mar 10, 2009 at 5:54 AM
    ccs368
    ccs368 Well-Known Member
    MA
    05 Access Cab SR5 4x4
    Also, I sprayed a lot of penetrating oil into the nut to try to break away every bit of corrosion that has accumulated between the threads of the shaft and the threads of the nut for easier removal.
  17. Mar 10, 2009 at 6:50 AM
    Pat
    San Diego
    Yeah thats was my only worry but I was putting new shocks on anyways so I didn't really need to keep the stock shocks in good condition.
    On the other hand, your ways of taking it off are much better!! chris4x4 ftw.
  18. Mar 10, 2009 at 6:56 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Whew....I thought this was going to be a thread about removing tcBob.:eek:
  19. Mar 10, 2009 at 7:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Does he have a provision for a wrench to be paced on his head? :confused:
  20. Mar 13, 2009 at 10:15 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    lol
