removing the top nut?
Discussion in 'Suspension' started by Zombie Runner, Mar 9, 2009.
  1. Feb 19, 2019 at 12:22 PM
    man_4x4
    man_4x4 Member
    Manuel
    Toyota Tacoma TRD Sport 2011
    Hi guys... regarding this topic, I would like to ask how I can remove the top nut from the rear shaft. I tried to used the 8mm wrench but it was so tighten that the shaft got rolled and now I cannot loose the nut.
    I would like to ask if there's another option than cutting the shaft and kill the shock.
    Thanks
  2. Feb 19, 2019 at 1:33 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    might try to use a metal file and file the thread off opposite sides and then use wrench to hold in place while removing nut - and use lots of liquid wrench or PB blaster before and let it work its way through before twisting.
  3. Feb 19, 2019 at 1:50 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    FOR REAR SHOCKS-Spray penetrating oil liberally, clean out recess for Allen wrench well before attempting to insert wrench. It will strip easily if not fully seated in the recess. Loosen nut normally. It should loosen. If not, cut off stud just below nut with sawzall ( fast) or hacksaw (slow) . Install new shock with anti-seize on threads. Vice grips on the shaft did not work for me, sawzall did on Bilstein 5100. The 5100's have the allen socket, Monroes have a wrench flat, I can't remember the oem Bilsteins.
  4. Feb 20, 2019 at 8:28 AM
    man_4x4
    man_4x4 Member
    Manuel
    Thank you. I have the OEM Bilsteins on my TRD Sport 2011. They have the flat wrench that now it is completely rolled. I will try cutting the stud just below nut. It is possible to replace the hole shaft then? (If I wanted to use them back, or sell them)
  5. Feb 20, 2019 at 8:33 AM
    Troyken
    NY
    Once you cut off they are unusable, discard. I lost a 5100 shock that way.
  6. Feb 20, 2019 at 8:40 AM
    man_4x4
    man_4x4 Member
    Manuel
    :annoyed:
  7. Feb 20, 2019 at 12:12 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    IF you can weld or have access to a welder, you can weld a small lever to the top to hold and cut it off when your done. The shock will still be good after.
  8. Jul 22, 2019 at 3:51 PM
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Need to replace cracked bushings on front struts. Won’t the weight of the truck be sufficient/safe enough to remove the nut and replace the cracked bushing? Torque the nut to 20lb as stated in the torque spec sheet.
    Ordered these replacements for 6112s (2016 Tacoma)
  9. Jul 22, 2019 at 4:34 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Unfortunately you would have to disassemble to replace all the bushings and not just the top.
    Tibetan Nomad[QUOTED] likes this.
  10. Apr 15, 2020 at 10:13 AM
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    Thank you!
