Removing TRD Decal Residue?
Discussion in 'Detailing' started by 3JOH22A, Apr 14, 2019.
  1. Apr 14, 2019 at 2:24 PM
    3JOH22A
    3JOH22A [OP] Cunning Linguist
    District 6ix
    3rd Gen TRD Off-Road
    Used a heat gun and peeled off one of my TRD bedside decals. However, WD40 doesn't work for removing the adhesive residue? Also tried Turtle Wax bug & tar remover and Mr Clean magic eraser to no avail. I found WD40 worked well on my previous 2nd gen. Is there something different with 3rd gen decals?
  2. Apr 14, 2019 at 2:31 PM
    TheGman72293
    TheGman72293 Member
    2003 Double Cab 4x4 TRD
    Try Goof Off, I've used it on numerous things over the years. Just try in a small spot on your ride to make sure you don't destroy the paint. Used it on my 03 Tacoma for adhesive, tar, bugs. Works great.
  3. Apr 14, 2019 at 3:23 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    3m adhesive remover. Sometimes you have to get a good bit of spray on the towel, hold it to the sticky residue to soften it, then rub a bit off at a time. Repeat...
    CS_AR and 3JOH22A [OP] like this.
  4. Apr 25, 2019 at 11:38 PM
    Atowns40
    Atowns40 Well-Known Member
    Redding, CA
    17 DCLB TRD OffRoad Inferno
    Following. Have same problem as OP
  5. Apr 28, 2019 at 8:33 AM
    DougDrag
    DougDrag Well-Known Member
    Purchase a 3m Eraser Wheel.
    3JOH22A [OP], tacoma_ca and jclamdip like this.
  6. Apr 28, 2019 at 8:46 AM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    Goof Off works wonders, used it when I removed my logos/emblems. Test it on a small area first to be sure but no reaction with paint was seen through the years I've used it. Be sure if using a rag to keep using a clean portion to run adhesive away otherwise you will just spread previously removed adhesive over a large area.
    Random side note: If you ever remove a soft bed cover and you want to remove the velcro (if applicable) from the bed front top rail, DO NOT use Goof Off.
  7. Apr 28, 2019 at 8:53 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Gasoline ;)
  8. May 12, 2019 at 4:51 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Use goo gone NOT goof off, goof off will eat through your clear coat
    tacoma_ca likes this.
  9. Jan 18, 2020 at 5:15 PM
    jclamdip
    jclamdip Well-Known Member
    Bill
    Wichita, Ks
    2012 4door PreRunner Sport
    He is correct the 3M wheel works like a champ and is by far the easiest way to remove any decal. I did my truck in about ten minutes.
    3JOH22A [OP] likes this.
  10. Jan 19, 2020 at 6:21 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I use denatured alcohol for removing adhesives. Soak a paper towel, rub lightly, and be patient. Just don't leave the soaked paper towel in constant contact with the clear coat too long, it may soften it a bit.
  11. Jan 19, 2020 at 1:02 PM
    jet speed
    jet speed Well-Known Member
    Ohio
    2017 TRD OR DCSB
    I’ve had great luck with Goo Gone, just wipe it on, let it sit for a few seconds, and wipe it off.
  12. Mar 8, 2020 at 10:36 AM
    3JOH22A
    District 6ix
    :thumbsup: Couldn't find a 3M eraser wheel in stock locally, but I bought a PowerFist branded 4" one. Worked well!
    BTW all the N95 chemical masks and filter cartridges (meant for painting, etc.) are cleaned out from the store. People are getting scared of the cervezavirus.
  13. Mar 8, 2020 at 2:15 PM
    jclamdip
    Bill
    Wichita, Ks
    You don’t need the goo gone or any other chemicals, put it in a drill and erase it.
    Very, very simple with little fuss.
  14. May 9, 2020 at 2:22 PM
    J bug
    J bug Well-Known Member
    Jeremy
    GTA
    2019 Trd pro
    19 TRD PRO REVTEK 1.5" LIFT BORA 1.25" WHEEL SPACER '20 TRD PRO TAIL LIGHTS W/ MESO TOTAL STAGE 1 LED LIGHTS MORIMOTO 2STROKE LED HEAD LIGHTS RUNNING4TACO RAPTOR LIGHTS MESO MAP/DOME LIGHTS MESO FULL CABIN CHROME DELETE LEER XQ CAP BIG COUNTRY CUSTOMS BED STIFFENERS
    Believe it or not olive oil works best
  15. May 9, 2020 at 5:13 PM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
  16. May 11, 2020 at 3:57 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I know that lots of folks have used and like adhesive remover wheels. (I used them too.) I would offer one big caution though. Although they say they don't damage paint, there's simply no way that rubbing anything against your paint doesn't damage it at some level.
    As for my go to product for adhesive removal, I've tried a ton of them and the only one I use these days is:
    https://www.amazon.com/3M-General-Purpose-Adhesive-Cleaner/dp/B0002NUO6K
  17. May 11, 2020 at 4:54 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2013 DCSB
  18. May 11, 2020 at 4:57 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Lund 5" Nerf Bars Undercover Tonneau Cover
    Another ticky for Goo Gone and NOT Goof Off. It did take a while but it took off all the residue when I removed my OR decals.
