removing uca bolt to install new uca's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robert benner, Feb 12, 2009.
  1. Feb 12, 2009 at 9:08 AM
    robert benner
    robert benner [OP] Member
    eastern PA
    09' taco sport dc lwb black
    TRD exhaust and intake, Shrockworks front bumper, AAL, full tint, 3/4" toytec spacer
    Hello: Got to the point of trying to get the upper part of the uca off of the nut, any tricks here? There is no way to get the nut out of the one end, am I missing something?
    Thanx. Rob
  2. Feb 12, 2009 at 9:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check out this thread:
    http://www.tacomaworld.com/forum/suspension/14507-total-chaos-uca-how-install.html
    I use a few extensions to help drive the bolt out. I start with a 3" 3/8 extension, and work my way to a 6" 3/8 extension. You will have to bend the fender well a little bit where the bolt is gonna hit the sheet metal, and make sure you move the airbag wires out of the way. You also may have to revomve a bracket on the driverside under the battery.
  3. Feb 12, 2009 at 9:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Bend the sheetmetal enough to slide out the bolt. Then re-install the bolt from the other side and bend the sheetmetal back when you're done.
  4. Feb 12, 2009 at 9:14 AM
    mjp2
    NJ
    As usual, Chris provides details whereas I just recommend using a BFH. :p
  5. Feb 12, 2009 at 9:17 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    +1. I had a hard time removing mine too, but that link helped. Also, just take your time... It does actually come out. :)
  6. Feb 12, 2009 at 9:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, a BFH works 99% of the time. :D
  7. Feb 12, 2009 at 9:22 AM
    tgr8st
    tgr8st Member
    +1 for a BFH, after you remove the batter and bend the sheet metal
  8. Feb 12, 2009 at 9:26 AM
    robert benner
    eastern PA
    Hello guys: Thanx. a bending I shall do!:)
    Rob
  9. Feb 12, 2009 at 9:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont have to bend much. As you drive the bolt out, watch where its gonna hit. Also, keep the washer near the UCA mount, as it will want to creep forward with the bolt as its being removed, and it will cause a binding of the bolt. Like others said, take your time. ;)
  10. Feb 12, 2009 at 9:32 AM
    robert benner
    eastern PA
    Where I am having the issue is the one nut that is towards the front of the truck, cannot get it off to slide the bolt back and then bend fender!
    Thanx. Rob
  11. Feb 12, 2009 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you post a pic?
  12. Feb 12, 2009 at 9:36 AM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    OK.. I just realized how exposed the ball joint is on the new UCA's. doesnt' that make it more prone to failure?
  13. Feb 12, 2009 at 10:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. I have had mine in mud, under water for extended periods, and actually had wet concrete dry on the uniball. No issues.
  14. Feb 12, 2009 at 10:16 AM
    kristopherl
    Cincinnati, Ohio
    wow.. that's good...I just have bad luck and figured I would be the 1/10 of a percent it happened to when I do it :eek:
  15. Feb 17, 2009 at 5:28 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I've read that the uniballs can squeek sometimes. But I've never heard anyone complain about the squeek. Do they squeek or not? I was planning on getting TC UCA's and Icon coilovers but don't know if I can live with the squeek. maybe light racing UCA's would be better for me.
  16. Feb 17, 2009 at 5:31 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    TCs typically don't squeak from the uniball -- camburg arms typically do.
    If you don't put enough grease in the bushings they'll squeak.
  17. Feb 17, 2009 at 6:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What He said^^^^^^^^^^^^^^^^^
    I have only heard of 1 or 2 TC UCA's that have made noise, and that was from not enough grease opon install.
  18. Feb 17, 2009 at 6:53 AM
    LonghornTaco
    Minnesota
    :wave: Guilty...
  19. Feb 17, 2009 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl:
  20. Feb 17, 2009 at 10:02 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I had the same concern when I got my TC UCAs. Like chris4x4 said, they are fine. And in the chance one of the uni balls do go out. TC sells new uni balls and rebuild kits for $40 bucks.
