Repainting front bumper help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobfm10350, Jun 9, 2010.
  1. Jun 9, 2010 at 8:57 PM
    bobfm10350
    bobfm10350 [OP] Well-Known Member
    Deric
    Austin Texas
    06 PreRunner TRD Off Road
    Access Limited Tonneau, Hawk LTS Brake Pads, SP Performance Slotted Rotors, Goodrich G-Stop Brake Lines, Thule Roof Rack, Bilstein 5100s Front and Rear, Eibach Coil Springs, Cabela's Floor Mats, 265-75-16 Duratracs, Fog Light Anytime Mod, D-Rings Mod, USA Spec PA15 TOY Ipod Adapter, Gorilla Lock Nuts, K&N Drop-In Air Filter, Wet Okole Seat Covers Front & Rear, Toytec 1.5" AAL, Viper 5901 Car Alarm
    Has anyone repainted their front bumper? Mine has a bunch of scratches in it so i'd assume i'd have to take some sandpaper to it but beyond that im pretty lost.
  2. Jun 9, 2010 at 9:32 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    I would say that you do need to sand, but not because of the scratches, but because the paint needs something to grab onto, or hold onto.
    You should wet sand with a high grit of sandpaper. Dip the sandpaper in water, and then sand. This will provide a very smooth surface to paint, but also provide a surface for the paint to adhere to and grab onto.
    After that, you should clean the surface. Clean with rubbing alcohol, or even windex. And wipe away with a paper cloth, and continue to do so until you do not see any left over residue on the cloth.
    Then spray paint, follow the directions on the can. Spray one coat, then spray another coat 15 mins later. That's very important. If not completely covered, spray again 15 mins later.
    There are many threads on this already, a search will reveal many tips and threads on this. Also try going on google and doing a search, or even youtube?
    Hope that helps.
  3. Jun 10, 2010 at 3:01 AM
    375taco
    375taco controlled pair?
    2010 TRD Sport 4x4 DC SB
    OME lift w/ 1" spacer. Built Right UCA's. Tinted all the way around. De-badged. Trimming up front
    send me a pic i will tell you if you need to take the bumper off or just touch up. Might have to take it to a shop. haha
  4. Jun 10, 2010 at 3:53 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    x2..Unless you have all the right tools to DIY,the effort and cost of trying to repaint it yourself, it would be better to take it to a shop so they can match it correctly. Unfortunately, daily driving will produce rock chips/scratches so the new paint will eventually have the same flaws..Your best bet is post in the buy/sell/trade forum , there are always guys here upgrading there bumper so you may have luck getting one cheap! good luck.
  5. Jun 10, 2010 at 6:30 AM
    wcm608
    wcm608 Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    My opinion is that the front bumper will need a flex additive to the paint or it
    will probably crack. Take it to a professional and have it done right.
  6. Jun 10, 2010 at 10:11 AM
    bobfm10350
    Deric
    Austin Texas
    I'm thinking I'll just look for a used one in hopefully better condition than mine
