Repairing Rear Wheelwell Rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by Murrfk, Apr 17, 2011.
  1. Apr 17, 2011 at 4:08 PM
    Murrfk
    Murrfk [OP] Well-Known Member
    Manitoba, Canada
    1996 Tacoma 2.7l
    I have several inches of rust above my rear wheel wells. I would like to repair this properly. I am aware of the need to get it back to bare metal, but anyone have any tips, ideas, sources, etc. for what I can do to fix it?
  2. Apr 17, 2011 at 8:59 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Let it rust!! :D Grind it all down. or replace the entire fender. It's going to involve alot of cutting and welding new sheetmetal back onto. Also Bondo.
  3. Apr 18, 2011 at 7:06 PM
    Murrfk
    Manitoba, Canada
    1996 Tacoma 2.7l
    I heard that there are replacement REAR fenders for rust above the wheelwells, and that they now glue in. Anyone know anything about that?
  4. Apr 21, 2011 at 5:29 PM
    Murrfk
    Manitoba, Canada
    1996 Tacoma 2.7l
    Has anyone fixed their rear fenders?
  5. Apr 21, 2011 at 5:48 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I would just sand/cut out the rust, paint it (I would bedline it with herculiner) and throw fender flares over it to cover it up.
  6. Apr 25, 2011 at 10:44 AM
    Murrfk
    Manitoba, Canada
    1996 Tacoma 2.7l
    I don't think fender flares would fit, and I want to do a good job. That wheelwell rust is the only major cosmetic problem with my truck. Has no one had to fix this?
  7. Apr 25, 2011 at 11:21 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Remove excess rust and treat with rust converter, then use your coating of choice.
  8. Apr 25, 2011 at 2:12 PM
    kmok
    Kyle
    Columbus, Ohio
    Tacomas come factory with fender flares. Just giving you options.
    These:
  9. May 7, 2011 at 2:00 PM
    Murrfk
    Manitoba, Canada
    1996 Tacoma 2.7l
  10. May 8, 2011 at 5:49 PM
    Murrfk
    Manitoba, Canada
    1996 Tacoma 2.7l
    Well, since I couldn't find any place that sold the wheel arches, and since rust never sleeps, I decided to make a set out of the skin of an old fridge.
    I took a power wire brush to the two effected areas, cleaned them off, and cut the rust all the way back to good clean metal. Then I painted inside and out with rust primer paint.
  11. May 8, 2011 at 5:59 PM
    Murrfk
    Manitoba, Canada
    1996 Tacoma 2.7l
    Next I went over to my good friend Dwight's, because he can weld, and he tried out his new mig. It was his first time trying autobody panels. We made sure to disconnect the battery before we started to weld.
    This was new for both of us. I think friend Dwight did a fine job!
    I will try to get it puttied, primed and painted in the next few days.
  12. May 8, 2011 at 8:19 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Better off looking for another box, once the cancer starts there is no fixing its just a cover up.
  13. May 8, 2011 at 8:27 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    strong work. my 96 T100 needs this and I've been considering doing this to get rid of as much as possible and then slapping some flares on to cover up novice body work. keep the pics coming.
  14. May 8, 2011 at 8:29 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Looks good, a little sanding+paint and it will be good as new!
