Repairs needed or normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The Magic Potato, Mar 27, 2025.
  1. Mar 27, 2025 at 9:50 AM
    The Magic Potato
    The Magic Potato [OP] New Member
    Antonio
    '18 Black TRD OR
    Stock
    Hi there, new member here
    18 TRD OR 130k miles
    About 6 months ago I did some basic servicing. When I got to the front end I noticed that both front axles had just a little bit of play in them up and down and side to side at the yoke. I didn't think anything of it until I did my service again last week. If you could see the attached video I'm not sure if this amount of play is normal or not because I don't see any oil coming out of the front diff. Everything about the CV axles is fine boots are fine no tears or anything that believe it to be unrelated anyways. I know for certain that the driver side has significantly more play than it did before. Truck drives, feels and sounds as it always has ambut I'm not sure if this is a fix or leave it alone type deal
    Thanks
    https://photos.app.goo.gl/zVDRZcc2BGVBDGcf7
  2. Mar 27, 2025 at 2:34 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I can't seem to get your video to play properly for some reason...
    It's completely normal for the driverside CV to have (what some might feel is excessive) play in it. The ECGS bushing swap should reduce it a good bit (although probably won't entirely eliminate it).
  3. Mar 27, 2025 at 2:37 PM
    MGMDesertTaco
  4. Mar 27, 2025 at 2:49 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Normal.
    The Magic Potato[OP] likes this.
  5. Apr 2, 2025 at 6:11 AM
    The Magic Potato
    Antonio
    '18 Black TRD OR
    Stock
    Thank you for the replies! Friend of a friend that works as a Toyota dealership mechanic says some play is normal too or just to keep an eye out for anything leaking
    Willy Lump Lump likes this.
  6. Apr 2, 2025 at 7:40 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    I had a service tech tell me to check all the trucks on the lot, so we did. It was more fun than anything.
