Replace bad Falkens?
Discussion in 'Wheels & Tires' started by Pruby18, Apr 5, 2020.
  1. Apr 6, 2020 at 12:10 PM
    #41
    cgs2k2
    cgs2k2 old man
    I've had a dozen different ATs, all seasons, and MTs on my trucks - Duratracs have been the best all around tire. On road, offroad, long snowy north east Ohio winters. They are especially good in the snow, so I'm surprised to hear you had a bad experience with them in the snow. Sounds like you have bad luck with tires.
  2. Apr 6, 2020 at 12:14 PM
    #42
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Had my Wildpeaks for 2 years now,not a single problem.
  3. Apr 6, 2020 at 1:47 PM
    #43
    Pruby18
    Pruby18 [OP] Well-Known Member
    2019 DCSB OR 4X4
    Maybe . Never any problems with my old car. Maybe was just a situation of ice that no tire would save me from.
  4. Apr 7, 2020 at 6:36 AM
    #44
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ??? have you considered it may not be the tires? After 4 attempts you might consider it is an issue with the installer and their method / equipment. I have always had problems with DT and their poor balancing results. I will buy from them on-line but take my tires to the dealer for mount and balance. I have 30k miles on my wildpeaks now and no issues (wear or balance) - mounted and balanced at a Toyota Dealer for less than $15/tire. Before you spend the $ on new tires consider having them rebalanced by you local Toyota Dealer. BTW - this is the ONLY work I will allow the stealership to do on my truck. The of the general maintenance I do on my own.
    #44
  5. Apr 7, 2020 at 6:43 AM
    #45
    Abelgonz
    Abelgonz Well-Known Member
    Abel
    Arizona
    2017 Barcelona Red Tacoma TRD OR
    Take a look a this. Maybe they are mounted incorrectly. I had the same issue with my Wildpeaks.
    https://www.topgear.com.ph/features...the-sides-of-new-tires-are-for-a2600-20181008
    #45
    Pruby18[QUOTED][OP] likes this.
  6. Apr 7, 2020 at 6:49 AM
    #46
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I don't think Generals get much love on here. They should. I've had the AT2 for 60K and now the X3. I've been pretty happy with both. The X3 is heavy and talks a little on the road, but that's what a mud tire does.
    I think you should check out what they have that fits your needs.
    Pruby18[OP] likes this.
  7. Apr 7, 2020 at 7:06 AM
    #47
    eurowner
    eurowner Duke Sky
    Scoty
    The newest Coats balancer, from 2018+, as of 11-2019 does not have an adapter/arbor to correctly hold the TRDOR alloy wheel.
    I had my winters reinstalled 11-19, and the truck shook over 70mph. Brought it back, said the work wasn't done correctly and rebalanced. I had an important 1400 mile road trip to do and the truck shook over 75mph, and shook for 700 miles. I had run these tires before and had always used the same shop. I bought the truck to Discount Tire and asked them to balance the wheels. No problems after that!
    Tell this to my local shop and they start looking into the situation. They had an older Hunter balancer until a few months before my last swap. The owner found that the new Coats did not have an arbor for this wheel, but he found a fix using a Hunter arbor to fit. And since then I have not had a problem.
    GoldenBrew[QUOTED] likes this.
  8. Apr 7, 2020 at 8:25 AM
    #48
    SoCal TacoOR
    SoCal TacoOR Life at Redline
    Kommie Kali
    17 DCSB TRD OR Super White
    No issues here with SL Wildpeaks....either you have a bad set or tire or the installer is not quite competent.
    JFick likes this.
  9. May 5, 2020 at 11:32 PM
    #49
    Malore
    Malore Well-Known Member
    Oregon
    '25 Celestial Silver Metallic Tacoma TRD Off-Road
    What's the latest, amigo? Interested to hear how this turned out for you.
    #49
  10. May 6, 2020 at 11:18 AM
    #50
    Pruby18
    2019 DCSB OR 4X4
    I switched to toyo open country a/t 3’s. Problem is completely gone, tires are a bit lighter as well. They don’t looks as “cool” as the wildpeaks but I’m definitely glad I don’t have those vibrations anymore.
  11. May 6, 2020 at 11:39 AM
    #51
    Malore
    Oregon
    Good to know. Thanks for the reply!
  12. May 6, 2020 at 12:13 PM
    #52
    TankerTool
    TankerTool Member
    PA
    2016 DCLB OR Inferno
    I have the same issue with my Falkens on stock rims. They balance just fine and ride great till i get a few k miles down the road. Atleast one needs weights moved by the 5k mark.
  13. May 6, 2020 at 12:14 PM
    #53
    Malore
    Oregon
    Well you guys certainly aren't making me feel any better about ordering my 275/70/17 this morning. HA! :(
  14. May 6, 2020 at 1:00 PM
    #54
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Install them correctly and they’re fine
    Maticuno likes this.
  15. May 6, 2020 at 1:38 PM
    #55
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My Duratracs have the 3 peak snow designation. Sold off my dedicated winters since these performed just as well. Love 'em.
    Best "rain rating" of them all, and considering how close they look to a M/T tire, I just love how quiet they are.
  16. May 6, 2020 at 6:12 PM
    #56
    Pruby18
    2019 DCSB OR 4X4
    when you take them in 4 times for rebalancing there is a problem. New tires and no problems at all. I must of got a bad set.
  17. May 6, 2020 at 6:43 PM
    #57
    hiroslammer
    hiroslammer Well-Known Member
    Carlsbad,CA
    2016 OR 4x4
    I’ve gone through two sets of KO2s and a set of Falken Wildpeaks, this go around I got a set of the Goodyear Wrangler Ultra Terrains only available through Discount tire. The Goodyear UTs have been great so far, take a look at them.
    Tocamo and Pruby18[OP] like this.
  18. May 6, 2020 at 8:50 PM
    #58
    Malore
    Oregon
    Did the shop take care of you (also using discount tire) or did you have to sell privately and buy new tires that way? Nervous for mine now!
  19. May 6, 2020 at 10:26 PM
    #59
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Nitto Terra grapplers
  20. May 7, 2020 at 6:07 AM
    #60
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Discount tire has a really good customer satisfaction policy. When I gave Wildpeaks a try, they happily swapped them out with about 1000 miles on them for a better tire.
