Replace OEM JBL sub and add an amp?
Discussion in 'Audio & Video' started by like2detail, Apr 25, 2018.
  1. Feb 5, 2019 at 7:36 AM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    I waited 5 months for my truck w/ JBL to be built. I enjoy it a lot. I'm not listening to that much drum & bass and jungle any longer, so I don't notice anything lacking. The mids and highs could be a bit better, but bass output is good for me. Hell, I had to go two notches down from mid-point on bass setting in the head unit just to not draw attention. Where I live, bump in the wrong part of town (hell, the wrong block) and your shit gets broken in to. If I want to push the audio, I can.
    I did have the driver front dash speaker short out; warranty covered it though. I think the factory didn't connect the leads completely.
    If you do replace the system, save all of it and sell here. People look for that stuff. The factory sub box especially.
  2. Feb 5, 2019 at 7:39 AM
    Professional Asian
    Professional Asian Ridgeline Enthusiast
    Andrew
    Eureka, California
    2017 DCSB TRD off road MT [OVtuned]
  3. Feb 5, 2019 at 7:57 AM
    John C
    John C Well-Known Member
    2016 TRD off road
    Actually it wasn’t that heavy lol. Then again I had another person helping me the whole time. The box its self is light the subs are what’s heavy.
  4. Feb 5, 2019 at 8:01 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Interesting. Has the JBL system gotten any better?
    Had it on my 08 and it was terrible! Replaced deck so my wife could have backup if she drove. That killed the sub so ended up replacing all the speakers with Focals and a JL 10” sub. Sounded really good once it was all done.
  5. Feb 6, 2019 at 3:26 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    The JBL is ok. It's better than stock. But I replaced my stock on my '17 with Kickers and it was Great!!! They sounded better than my current JBL...
    shane100700[QUOTED] likes this.
  6. Feb 6, 2019 at 3:32 AM
    House Forsaken
    Paul
    Thanks! I found this post too, had a lot of good info https://www.tacomaworld.com/threads/upgrade-3rd-gen-jbl-speakers.517420/page-2 (post 31). Unfortunately the Kicker speakers I currently have are 4ohm. I'll have to look into those infinity speakers! Maybe changing the speakers will give me the louder and better sounds I'm looking for!
  7. Feb 7, 2019 at 5:27 AM
    fivefoot
    fivefoot Scarlett, Scarlett Tacoma is the name!
    Temo
    Texas Panhandle
    2012 Tacoma TRD Offroad Barcelona Red
    The JBL in my 2012 was "ehhh". It would lose bass around 25-30 and would just sound flat. The speakers were a joke too. Agree that they are slightly better than stock, not by much. Once I replaced the speakers and the subwoofer, it sounds amazing now. I am using 2.7Ohms speakers and dual 150 JL Audio subwoofers.
    TacoTuesday!! likes this.
  8. Feb 7, 2019 at 5:32 AM
    fivefoot
    Temo
    Texas Panhandle
    My box weights 65 pounds, I don't know how much each sub weights. Im gessing around 10 pounds each. Wasnt too bad putting the box inside the cab, did it all by myself one weekend.
  9. Feb 7, 2019 at 6:11 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I don't have the JBL system, but I added an under seat 8" powered Sub. I spliced the rear speaker wires to do this and all is hunky dory for me. Yes it's far from earth shattering Bass, but it's good. Did that and the "must change" Subaru Tweeters.
    @like2detail, perhaps you could do something similar "and" keep the JBL Sub hooked up.
  10. Feb 10, 2019 at 9:02 PM
    Checkvalve
    Checkvalve Well-Known Member
    San Diego CA
    2013 DCLB Spruce
    @fivefoot : Do you have part/model numbers for the infinity speakers you used? Also, can you tell me a little about the adapter I see for your RCA inputs to the amp? That's my main question right now is how to get a clean signal to an amp to power whatever sub I go with in the rear seats...
  11. Feb 11, 2019 at 5:14 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    *Sorry to revive an old thread, but I was under the impression I had to change out my JBL head-unit also in order to get better sound of of Non JBL speakers. Is this not entirely accurate??
    You can keep the factory headunit, the issue is there's no eq besides the shitty 3 band it comes with. An aftermarket headunit and the factory jbl system is louder and cleaner sounding than the normal factory setup. Basically any aftermarket headunit will make whatever speakers you're running sound better due to the audio adjustment options.
    *I have some Kicker speakers I had put in my '17 that I'd like to put in my '18, but haven't because I've read just changing out the speakers wouldn't make a difference on the JBL systems.
    It'll help a bit, but you're still stuck pushing them with the factory headunit. It muddies the sound since its sending all frequencies to the speakers.
    *How can I add an amp to get more power to the speakers?
    Place one under your seat and run it to the factory wiring or run new wires.
    Replying to someone and butchered the quote option. Made my own
  12. Feb 14, 2019 at 1:42 PM
    fivefoot
    Temo
    Texas Panhandle
    Everything I used in this upgrade came from Crutchfield, so they include everything you need for an easy sway. With that said, here are links to what I used:
    Front Speakers: https://www.crutchfield.com/p_108P9613IS/Infinity-Primus-PR9613is.html
    Rear Speakers: https://www.crutchfield.com/p_108P6512IS/Infinity-Primus-PR6512is.html
    Amp: https://www.crutchfield.com/p_206CXA3001/Kicker-43CXA300-1.html
    Speaker wire to RCA: https://www.amazon.com/dp/B00I4EBOYK/ref=cm_sw_em_r_mt_dp_U_Z-DzCb5EPED8K
    Subwoofers: https://www.crutchfield.com/p_13692079/JL-Audio-8W1v3-4.html
    If you don't have the JBL package, you can get a line level converter and tap on to each of the rear speakers to get a signal for your amplifier. Youll need this: https://www.amazon.com/Kicker-KISLO...s=gateway&sprefix=line+level+c,aps,161&sr=8-6
  13. Feb 16, 2019 at 6:04 PM
    ncmetalfan
    ncmetalfan New Member
    Dan
    2017 DCSB Limited
    I went a similar route as fivefoot today, but only door speakers so far.
    Front door - Infinity Reference REF-9632ix
    Back door - Infinity Reference REF-6532ex
    Lots of Dynamat, will be doing more deadening/insulation/dampening as well.
    Now my front speakers were already starting to sound bad anyway bc I blast my music but just swapping those out and the dynamat made a huge difference. The EQ is slightly different now IMO (or I could just be not used to the better sound yet) but I’m still very glad I spent the 5-6 hours and few cuts to my hands doing it lol.
    I don’t know enough about audio yet but I may try a different front speaker eventually, maybe the 3 way like fivefoot did.
    Guess I’m just going to order Memphis audio 2.5” to replace the dash since that’s about the only option without getting into wiring?
    Still researching sub options
    May eventually change HU
  14. Feb 24, 2019 at 6:28 PM
    Swilly9
    Swilly9 Well-Known Member
    2018 White Tacoma TRD Sport
    I've been pretty disappointed in my JBL "upgrade"... I was excited about everyone going with these Kicker CS and Subaru Kicker Tweeter upgrades.. but realized they are for Non-JBL.
    Now I'm debating on going that route on just replacing everything or just live in regret.
  15. Mar 14, 2019 at 9:04 AM
    #35
    Swilly9
    Has anyone just replaced the jbl sub without adding and amp and heard improvements?? I was thinking bout replacing it with kicker 8” shallow sub ...
    Taco.16666 likes this.
  16. Mar 14, 2019 at 9:13 AM
    #36
    fivefoot
    Temo
    Texas Panhandle
    I did at first. Replaced the fac sub with a Pioneer 8” shallow. The factory amp didn’t have enough juice to really provide the power the sub needed. And it also sounded like crap because I’m guessing the stock subwoofer box volume was too big for the Pioneer. So I didn’t go that route and instead replaced the factory box with a custom one and added an amp just for the new subs. Kept the factory amp in place though. So my truck has two amps now.
    Swilly9[QUOTED] likes this.
  17. Mar 14, 2019 at 9:17 AM
    #37
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Sub'd... :spy:
  18. Apr 17, 2019 at 7:04 AM
    #38
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
    Anybody know where the amp is in a double cab JBL system?
  19. Apr 17, 2019 at 7:08 AM
    #39
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    If you still have factory box, would you mind filling it with water and telling us the volume?
    Then we can use that info in the future to adjust with fiber fill or internal block outs or whatever to tune it for an aftermarket sub :)
  20. Apr 17, 2019 at 8:52 AM
    #40
    fivefoot
    Temo
    Texas Panhandle
    That box is somewhere in a recycling center now. fiber would not work as it would act as a bigger box. closed-cell foam would be your best way to reduce volume without adding any weight and closed-cell foam is easy to work with.
    Alnmike[QUOTED] likes this.
