Replace OEM single disc with six disc player?
Discussion in 'Audio & Video' started by sdupp, Mar 7, 2007.
  1. Mar 7, 2007 at 2:53 PM
    sdupp
    sdupp [OP] SC Member
    SC
    White 07 PreRunner Double Cab SR5
    I have the standard OEM Single disc stereo in my truck. Thinking about buying an OEM six disc stereo form a friend who is upgrading to an after market system. Both trucks are 2007 Tacoma Double cabs. My question is will the six disc plug in without a problem. Its Not the JBL system but dose have steering wheel controls. :confused:
    Thanks!! Stan
  2. Mar 7, 2007 at 4:58 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    it should not be a problem since it's the same brand it should fit nicely, but look at the installationkit is it the same set-up? keep us posted
  3. Mar 8, 2007 at 4:06 AM
    sdupp
    SC
    I don't think you fully understood my question. I want to switch out one Head unit for the other. Both are Tacoma OEM radios. The only difference mine is a Single disc and his is a Six disc. I no the fit won't be an issue. My Question is when I plug in the wires will there be any issues? I am assuming the wiring harness is the same.
    Thanks for your help.. Much Appreciated!!
  4. Mar 21, 2007 at 1:22 PM
    Angel Gurrea Realyvazquez
    Angel Gurrea Realyvazquez New Member
    Hey, may be is to late, but the tacoma JBL 6 CDs is not compatible with connectors of the SIGLE DISC, you need Amplifier and the harness, see you!
  5. Mar 25, 2007 at 10:06 AM
    sdupp
    SC
    FYI
    The OEM six disc changer fit like a glove and the wires plugged right in... No Problems!! It was the easiest radio I've ever replaced.
    Stan Dupp
  6. Oct 28, 2008 at 12:54 AM
    hurricane
    hurricane Member
    Whitehorse
    speedway blue
    wheels,stereo, step bars,roof rack.
    In the end was it the premium JBL that you put in???
    Later,
    WV
