Replace the entire bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LilTuffGirl, Dec 23, 2011.
  1. Dec 23, 2011 at 6:13 PM
    LilTuffGirl
    LilTuffGirl [OP] Well-Known Member
    Nikki
    WV
    3" rough country lift leather
    I screwed up big time tonight :( Was headed to work from the new place I just got way out in the country.. (i'm a 911 dispatcher btw)... Yea hit the breaks in the middle of a turn like a MORON - roads are wet... rear end slides and I start to get it back but something happens (can't remember just remember feeling like wow that was close then f.....) I start going towards a drop off and have NO idea where it goes to so I make it go towards the tree/guard rail.. where I stop.. :( side of the truck hits.
    Thankfully my boyfriend who is a deputy was behind me... He got the tow truck out there to pull me away from everything.. and told dispatch I was going to be late :(
    I guess I came out lucky since I was able to drive it to work.. and I was only 25 min late lol. SO happy the tail lights only pop in and out!! It was hanging off but we just popped it right back in!
    My back is starting to hurt along with my head. But otherwise i'm fine. DIdn't think i'd feel anything from side impact? I guess I probably was all tensed up since I KNEW it was coming :( All I could think of is how badly i want to cry since I only have liability. I can't keep her looking like this!!
    Oh yea.. question was.. Can I just cut and weld that part of the bed or should I replace the entire bed? I know that wont just pull out..
  2. Dec 23, 2011 at 6:20 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Ouch :( So was it icy? Or just wet? That seems like a wicked spinout for just a damp road. Hate to see a good taco all beat up like that :(
  3. Dec 23, 2011 at 6:20 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Luckily it was only the bed! And you weren't hurt any worse! I'm guessing the pain is from the tensing up...cuz it doesn't look like you hit too hard and it was the rear.
    The guard rail didn't hit your door? The first pic kinda looks like it did. Could be the angle and the lighting.
  4. Dec 23, 2011 at 6:22 PM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Wow glad you're ok. Look in your area on Craigslist to see if you can find bedsides from someone who put on glass. Any structural damage?
  5. Dec 23, 2011 at 6:29 PM
    LilTuffGirl
    Nikki
    WV
    Yes guardrail hit the door.. but I should be able to pull the dent out and repaint where it scratched the crap out of it.
    Drives straight! Whoo!!
    Apparently it's a horrible spot in the road where a lot of people wreck. The guy who lived there said he's had his mail box taken out so many times from wrecks he gave up and just got a PO box. And apparently a few years back that tree killed someone... Not sure if water just sits there or what? No one is surprised that's where I wrecked. Also cold as PISS outside and it started to snow just a bit ago. Probably didn't help much... And yes I was going over the speed limit.
    BUT my MAIN screw up was hitting the damn breaks in the middle of a sharp turn on a wet road (shouldn't do it any time.. but.. yea). I know better. not sure what I was thinking???
    I have my friend who's dad owns a salvage yard searching for a bed for me. Just not sure if it'll be cheaper to get entire bed or what? Although I'm sure if I can find one the same color it would be cheaper!! And I could switch it out. Just have to pay for the door then.
  6. Dec 23, 2011 at 6:35 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    you can replace the sheet metal to the outside of the bed no problem, they are bolted on. the door can be an easy fixed as well by any body shop. all they will do is "re-skin" the door by taking off the old sheet metal and installing a new side on. and believe it not..you can find actual OEM sides cheap on line for under 300 bucks each..prolly cheaper then what a body shop would charge.
  7. Dec 23, 2011 at 6:46 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    one of the reasons i have never, and will never, have "liability only" for my vehicle insurance. one little mistake and, well, you could be paying out the ying yang.
    glad you are OK, though, that's the main thing. if you can find a bed in that color, you should be fine without hitting the wallet (or the purse, in your case) too bad. good luck.
  8. Dec 23, 2011 at 6:53 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    glad you’r ok! and you'r was BF was behind you. and i was someone hit brakes in a turn the went off the road. never hit anything just slid in to hay filed. i stopped to make sure they wear ok.
  9. Dec 23, 2011 at 7:20 PM
    LilTuffGirl
    Nikki
    WV
    Ok cool deal. I just hope he can color match the paint since it is a almost 7 year old truck. I'm insanely picky about paint.. even though this one did have rock chips.. and back bumper has a bit of rust. Guess i'll have him take care of that too while he has the paint...
    I'll run around and get estimates monday. :(
    And I think it's cheaper in the long run just doing liability. I mean I paid for full coverage for 12 years of my life and NEVER used it (well ok once when my ex hit a deer in my old mustang.) but even then I've paid the insurance companies more than enough to buy an entire new vehicle by now! Actually a few if you count the motorcycle full coverage on top of that! (I will never have only liability on a motorcycle)
  10. Dec 23, 2011 at 8:24 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    It kinda depends on what your insurance rates are only a few of my cars are paid off so I only have that option on some of them one is a 2002 bmw m5 I got my I insurance quoted both ways and it wasn't much cheaper to do liability only there was about a 400 per year difference.
  11. Dec 23, 2011 at 8:35 PM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    Seems like a lot of crashes on TW lately.. Glad you're alright though.
  12. Dec 24, 2011 at 5:01 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    :eek:
  13. Dec 24, 2011 at 8:02 AM
    Tookie
    Tookie Well-Known Member
    Port Vincent, LA
    2009 DC TRD Sport
    Did they have VSC in '05?
  14. Dec 24, 2011 at 8:14 AM
    Tookie
    Port Vincent, LA
    2009 DC TRD Sport
    Glad you weren't on your bike :D
    This time of year worries me when I ride, not so much
    the weather down here, it's the people "celebrating"
    that I'm scared of.
    All in all, you didn't come out too bad on the damages,
    good luck finding a bed.
    Maybe time to do something like this :wink:
  15. Dec 24, 2011 at 8:29 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Sorry about your truck Nikki, glad to hear your OK. Good luck with the repairs.
  16. Dec 24, 2011 at 1:58 PM
    MonkeyProof
    SoCal- SGV
  17. Dec 24, 2011 at 4:43 PM
    KodiakToyTRD
    CO
    My 05 doesn't have this VSC.
  18. Dec 24, 2011 at 4:49 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
  19. Dec 24, 2011 at 10:44 PM
    LilTuffGirl
    Nikki
    WV
    No VCS and crap breaks compaired to the ones I was use to on the STi ;) I did one hell of a sweet drift too! Sucks the tree and guard rail had to end it all.
    I want to cry every time I look at my truck now :(
    Odd thing is - the road I wrecked on was one my ex husband use to LOVE riding the motorcycles on. I hated it because cars always go over the yellow line and there are random gravel spots. I always feared i'd wreck on that road... almost got hit head on once when I was riding.
    I am glad it was a wreck in the truck than on the bike!!!
    And thanks for the TTORA link! I'll have to remember my log in for there.. was on there a looonggg time ago when I dated a guy with a tacoma. Man I wish I had those wheels I bought him for it...
  20. Dec 24, 2011 at 10:48 PM
    KodiakToyTRD
    CO
    Hmm you bought a man wheels for his truck?
