Replace thermostat housing studs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Jul 4, 2020.
  1. Jul 4, 2020 at 3:15 PM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Was doing my thermostat today and the studs and nuts are toast. No chance of unthreading the nuts, the whole stud came out.
    '03 5VZFE
    Anyone replace these studs with bolts? What length have you used?
  2. Jul 5, 2020 at 2:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Why not get the correct studs and nuts .
    unless you broke the stud you have your length
  3. Jul 5, 2020 at 4:47 AM
    RacerP
    Chicago
    2003 4x4
    I have the whole thing apart on July 4, for such a simple job. Not really wanting to wait for ordering them online...
  4. Jul 5, 2020 at 4:57 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I'd find SS studs with the correct diameter and length and SS nut's to match and blue loctite the studs in. Aluminum is very unforgiving when it comes to having studs come out, threads tend to be removed also.
  5. Jul 5, 2020 at 6:50 AM
    RacerP
    Chicago
    2003 4x4
    Finally went with penetrating oil and a little heat to get the old nuts off. Then a wire wheel to the threads and going to use my old ones I guess...seem fine now.
    cruiserguy likes this.
  6. Jul 5, 2020 at 6:53 AM
    Running Board Man
    Running Board Man Well-Known Member
    Ace is the place where the helpful.....
