Replaced Cold Air Intake - Still Have Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbutton1, Feb 25, 2010.
  1. Feb 25, 2010 at 1:21 PM
    kbutton1
    kbutton1 [OP] New Member
    07 Tacoma SR5 Sport Off Road
    K&N
    I recently installed the TRD Cold Air Intake to get rid of that annoying vibration while in reverse or at 1500 rpm or less. Worked fine for about two days and noise returned.
    I checked all of the bolts and noticed one of them had some space between the black box on the intake and a bracket which holds the a/c line in place. I disassembled the unit, inserted a washer, tightened everything up and it worked like a champ. For about a week.
    NOW! I have the same noise coming from the cold air intake side AGAIN, but it sounds a little closer to the firewall. Checked for loose bolts - could not find any.
    Any hints? What can I check in the engine compartment? What can I check in the cabin?
    It's driving me crazy.
    Please do not suggest I turn up the radio.
    Thanks!
  2. Feb 25, 2010 at 1:36 PM
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    At work so I can't surf the forums too much but I remember reading a thread here about how the TRD intakes vibrate / rub on something. So a lot of people were buying those double sided foam square tape pieces and putting it on the side of the intake box. I'll see if I can find it.
  3. Feb 25, 2010 at 1:42 PM
    Endurozw
    Zach
    Birmingham, Alabama
    Well I found two things -
    Here's a thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74668-fluttering-sound-trd-cai.html
    Here's some tsb was in a thread as well that was interesting and sounded like your problem.
    Technical Service
    BULLETIN
    August 1, 2006
    ENGINE
    Title:
    AIR INTAKE HOSE RATTLE
    Models:
    ’05 – ’06 Tacoma (1GR–FE)
    EG046-06
    Introduction
    Applicable
    Vehicles
    Production
    Change
    Some 2005 – 2006 model year Tacoma customers (1GR–FE only) may complain of a
    rattle noise from the right front fender area while the vehicle is idling in drive or reverse.
    The air intake hose assembly has been improved to reduce noise from contact between
    the air intake hose assembly and fender.
    2005 – 2006 model year Tacoma vehicles equipped with the 1GR–FE engine and
    produced BEFORE the Production Change Effective VINs shown below.
    MODEL ENGINE PLANT PRODUCTION CHANGE EFFECTIVE VIN
    TacomaTacoma 1GR FE1GR–FE
    NUMMI 5TE#U#2N#6Z268587
    TMMBC 3TM#U#2N#6M002937
    Parts
    PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY
    17882–0P010 Same Hose, Cool Air Intake 1
    Warranty
    OP CODE DESCRIPTION TIME OFP T1 T2
    EG5035 R & R Air Intake Hose 0.5 17882–0P010 91 99
    Applicable Warranty*:
    This repair is covered under the Toyota Comprehensive Warranty. This warranty is
    in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s
    in-service date.
    * Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
    Toyota Supports ASE Certification
    Page 1 of 2
    AIR INTAKE HOSE RATTLE – EG046-06 August 1, 2006
    Repair Remove and replace the air intake hose.
    Procedure
    Air Intake Hose
    Air Cleaner Assembly
    N..m (kgf..cm, ft..lbf) : Specified Torque
    12 (122, 9)
    Page 2 of 2
  4. Feb 25, 2010 at 1:48 PM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    Had a 2007 4.0 6 speed that did the same thing. The noise you are hearing is where the air cleaner pipe goes through the inner fender well (the foam is just not thick enough to keep it from vibrating on the sheet metal). You can pull the assembly and try to put thicker foam around it (worked for a couple of weeks but came back again) or just cut the tube flush where it goes through the fender well (finally took care of it). Good luck, Fred.
  5. Feb 25, 2010 at 1:53 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I have an annoying rumble when I put the truck in reverse and i have the TRD CAI. Hmmm...
  6. Feb 25, 2010 at 1:59 PM
    huntinggunns
    Fred
    Oklahoma
    In progress
    If you pull the airbox and look at the sheet metal you will see a shiny spot where it is rubbing and vibrating. This should be where the noise is coming from. Take a look, Fred.
  7. Feb 25, 2010 at 2:06 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Thank you so much, I had the Air Intake TSB done and the vibe is back and really is bad when the engine is cold in cold temps, I will get a friend to help me do this for I am not taking it back to toyota for the fix......to the OP I wish you the best in finding a solution to your TRD intake vibration, mine is stock and rattles like crazy in reverse & low rpms even after the suppose fix.
  8. Mar 28, 2010 at 1:58 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Well today I finally took a better look at this rattle. It drives me crazy. :crazy:
    The dealer supposedly had done the TSB. :rolleyes:
    Well, the foam around the hose going into the fender is about 1/4" thick & the bottom part underneath which you cannot get to unless you take off washer reservoir had fallen out. Not that it mattered, it only was paper thick.
    I used camper shell dense foam all around the area. Its got the 3m sticky stuff on one side. Put it all back together & no rattle....unless...I put it in reverse & slowly back up. But only in reverse. I can put it in park & give it gas & no noise. :notsure:
    Well that is my rant on this stupid intake rattle. :bananadead:
  9. Oct 4, 2010 at 9:10 PM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    I'n having this exact same issue.... doesn't look like the new hose even fixes the problem, anyone find a fix on this?? Thanks
  10. Feb 20, 2013 at 11:46 AM
    THEDREWS
    THEDREWS New Member
    sr5 prerunner
    k&n air intake
    I have the same thing happen on my 2008 TRD prerunner. It sounds like marballs rolling around in the crankcase then settling in just to start up again then stop again. This is driving me insane, the dealer wants 105.00 dollars to diagnose it. Yeah right! I can't believe on these threads how many things this could be. Is there anyone out there that has any better idea on what the hell this rattle is? It appears that no dealer knows either. I bought a toyota on how good everyone said they are, but i'm leaning back towards GM. From the rattle at start up, to the ticking blower fan, to the compass light going out, to the glove box issues, to the squeaking left front end, to the knocking leaf spring. need i say more. I never had these small nuisances on any GM product.
  11. Feb 20, 2013 at 12:09 PM
    gjacobsjr
    gjacobsjr Well-Known Member
    Jerry
    Reno, NV
    12 Tacoma SR5 MagGrey on Black
    Black Raptor 16x8 Leer Shell Blacked out windows Pro Comp 3 in lift good year 265/75/16 Airaid CAI Cat Back 2 3/4 pipe with magnaflow and tip
    buy a newer truck
  12. Mar 22, 2014 at 10:28 PM
    Foxer
    Foxer Well-Known Member
    U.S.A.
    Access Cab PreRunner
    Yeap it's definately that tube... I just went back to the stock airbox after removing a trd intake and noticed it instantly... sounds like the noise vinyl material makes when you cut it with a sawzall and the blade catches it the right way it and vibrates. Does it on a cold starts and in reverse. (basically whenever the truck is more prone to vibrate)
    I like the cutting idea.. time to get out the sawzall and some varoius sockets 8mm thru 12mm. And a ratchet and extension.
    good times
  13. Mar 23, 2014 at 4:22 AM
    Bully
    Bully Member
    Charlotte
    06 TRD Sport DCLB 4x4
    I had it too. I just tweaked the tube and tightened the screw.....worked for me. So far
  14. May 5, 2014 at 1:23 PM
    forealz
    forealz Active Member
    Los Angeles
    07 PreRunner OffRoad TRD 33k
    Any chance one of you can take a pic with the padding you installed or weatherstripping mod?
