Replacement back-up camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Connormc11, Sep 16, 2017.
  1. Sep 16, 2017 at 5:46 PM
    Connormc11
    Connormc11 [OP] Jangler
    Connor
    Norfolk VA
    2010 DCSB TRD-Offroad
    Alright tacoma world I need some help. I just broke the backup camera. Can I get any cheap Amazon replacement and just splice it Into the exisiting four pin connector? I have it mounted on my swingout so it can be any camera I just want to reuse the existing wiring. Is this more complicated than I think? Any sugestions on cameras? I have the version where it displays in rearview mirror.
  2. Sep 16, 2017 at 5:56 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    IIRC the oem camera is 6v, aftermarket will be 12v. But the coax output should be the same. Don't know if that helps.
  3. Sep 16, 2017 at 5:58 PM
    Connormc11
    Connor
    Norfolk VA
    Sounds like I might have to run separate power for camera but should should be able to splice into stock video input wires.
    Doogz likes this.
  4. Sep 16, 2017 at 6:15 PM
    Connormc11
    Connor
    Norfolk VA
    What i really need is if anyone has the wiring diagram for the camera so I know which wire does what I can't find it.
  5. Sep 16, 2017 at 7:36 PM
    Connormc11
    Connor
    Norfolk VA
    Found what i needed. so now i just need to find a 6v camera...
  6. Sep 16, 2017 at 7:39 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Or you could run the 6v input into a relay that sends a 12v output to your new camera. In case you can't locate the proper 6v camera...
  7. Sep 16, 2017 at 7:42 PM
    Connormc11
    Connor
    Norfolk VA
    yea it seems like OEM is the only viable option for a 6v camera and it is still way cheaper to buy a 6v to 12v converter and camera then just a 6 volt camera.
  8. Sep 16, 2017 at 7:45 PM
    Justinlhc
    Those cheap ass license plate mounted cameras are garbage anyways. Make sure you buy one with the proper orientation so it transmits the way you want. Some have a wire you can cut to reverse the image if being used as a backup. I bought a tiny ~5/8" camera and drilled a hole into my bumper for it that worked pretty well. I could see the hitch ball from it so it was perfect.
  9. Sep 16, 2017 at 7:50 PM
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Maybe it will work with just bypassing the power from the harness and using a 12v lead from the reverse light to new camera?
    Justinlhc[QUOTED] likes this.
  10. Sep 16, 2017 at 7:51 PM
    Connormc11
    Connor
    Norfolk VA
  11. Sep 16, 2017 at 7:56 PM
    Justinlhc
  12. Sep 16, 2017 at 7:58 PM
    Connormc11
    Connor
    Norfolk VA
    Agreed, but i don't see that piece as a complicated piece of hardware especially if i add some silicone to it like i do with most cheap electronic items i put out in the elements. guess the only way is to find out.
  13. Sep 16, 2017 at 9:02 PM
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I'd definitely be interested in seeing your final setup. My oem camera also failed and I have an aftermarket in a separate location. Ideally I want to fix up the original location with a new setup.
  14. Sep 16, 2017 at 9:19 PM
    Connormc11
    Connor
    Norfolk VA
    yea i have it a bit easier since i cant put it in the tailgate handle anymore due to my tire carrier so im not limited by OEM camera.
  15. Sep 23, 2017 at 1:42 PM
    Connormc11
    Connor
    Norfolk VA
    ok. so i bought a camera that had a four pin connector, but when i cut it off it only had three wires... I'm assuming positive negative and a trigger wire?? ill attach some pictures and see if you electrical gurus could help figure out witch wires go where.
    Truck Pin Connector:
    Camera:
  16. Sep 23, 2017 at 3:09 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Yellow is video out I'd say. Yellow is the standard color for video on pretty much all electronic devices
  17. Sep 23, 2017 at 3:22 PM
    Connormc11
    Connor
    Norfolk VA
    Yea i agree but i dont know which pin it goes to on the truck harness.
    My guess is:
    Yellow -> CB+
    Red -> CV+
    Black -> CV- and CGND
  18. Sep 23, 2017 at 4:33 PM
    Larzzzz
    Larry
    MA
    Red is cb+, black cgnd, yellow cv+. Don't worry about cv-. That connection was most likely broken to avoid ground loops.
    B+ is positive 12 volts. Cgnd is ground
    Connormc11[OP] likes this.
  19. Jan 27, 2025 at 8:33 AM
    bsmithgsl
    bsmithgsl Active Member
    Billy
    Las Vegas
    2018 Tacoma TRD OFFROAD
    Speakers, amp, remote start, pop & lock, camper shell
