Replacement bed rail bolts
Discussion in 'Technical Chat' started by jackwithcorona, Apr 6, 2011.
  1. Apr 6, 2011 at 1:37 PM
    jackwithcorona
    jackwithcorona [OP] Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    ok so if youre like me, perhaps you might have stripped your (or a friends) torx bit bed rail bolts, you know the ones that hold the rail against the bed (sorry no pic). well there is a solution! instead of going to the dealer and getting another strippable bolt (not even sure the cost, but probably more expensive) you can go to home depot and get a replacement hex bolt like this:
    its a 6mm x 1.0 x 16 mm.
    also you can bring your stripped bolt with you to test fit to be sure but these are long enough for STOCK applications. if you are putting anything behind the bed rails, such as certain tonneaus require, you'll need a longer bolt.
    in place on the rails, unpainted:
    apologies if this is either old news or useless, but i figured i needed it, so someone else might. hopefully this is the right section lol
    Orco59 likes this.
  2. Mar 12, 2012 at 11:44 AM
    truckbike
    truckbike New Member
    Ta
    Maine
    Access Lorado tonneau cover
    Thanks for the info on the replacement bolts. I stripped mine today trying to install my Access Lorado tonneau... Any hints on how to get the bolts out once they're stripped?
  3. Mar 12, 2012 at 11:47 AM
    rcfreak201
    rcfreak201 Well-Known Member
    drill it out, OP thanks for the bolt details, ive either stripped or misplaced some bolts and only have the outside ones installed, ill be getting these sometime this week!
  4. Aug 16, 2015 at 9:30 AM
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    Do the sliding tie down points still clear the head with these?
  5. May 5, 2025 at 3:52 PM
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    Lots of posts on these bolts….any idea how to fix / repair / replace the nut plates?
  6. May 5, 2025 at 3:58 PM
    Clearwater Bill
    Billy
    Largo Florida
  7. May 5, 2025 at 4:05 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Drill out the nutsert or Dremel off the surface until it falls out but be sure not to expand the hole in the beside. You can either buy a tool to install replacement nutserts or use a longer 6mm bolt and some washers with a power drill instead. There are youtube videos on both. I did the diy version with my cordless impact but bought a few extra nutserts to practice with since the diy method is not foolproof. Too tight and you can break something, too loose and the nutsert either pops out or spins instead of grabbing. I used them to add some extra horn power up
    front. The diy method is dirt cheap but takes a few tries to figure it out.
