Replacement Leaf Springs 2006 Tacoma
Discussion in 'Suspension' started by bajapescado, Dec 6, 2008.
  1. Dec 6, 2008 at 11:11 PM
    bajapescado
    bajapescado [OP] member
    I carry a camper. My factory installed stock leaf springs appear to be sagging. I'm considering installing Timberns http://www.timbren.com/ to reduce the sway and support the load, as well as replacing the existing springs.
    What are the best after-market leaf springs for a 2006 Tacoma TRD that would lift the load? Don't mind if it is a stiff ride as long as the they support the load. I researched the following replacement springs, but they say, due to removal of the factory overload spring there will be a slight decrease (Alcan) or decrease (Deaver) in gross max weight handling capability over the stock leaf packs.
    • Alcan Spring Toyota Tacoma 4X4 and PreRunner 2005-Current High Performance Rear Leaf Spring Set and Accessories
    • Deaver Racing Toyota Tacoma 4X4 and PreRunner 2005-Current High Performance Rear Leaf Spring Set and Accessories
    Would it be best to just replace the springs with new stock leaf spring sets from Toyota?
    Would an add-a-leaf work? Not sure if they would be good with my already sagging stock leaf springs.
    Thanks
  2. Dec 7, 2008 at 1:14 AM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    You can pick up an Alcan AAL from toyteclifts.com for $80. That should cure the sagging issue and give you about a 2" lift in the rear from where it sits now.
  3. Dec 7, 2008 at 1:16 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Did you get the TSB done? Maybe do that, then get an AAL.
  4. Dec 7, 2008 at 6:34 AM
    rick
    rick `
  5. Dec 7, 2008 at 8:21 AM
    bajapescado
    I'm over the 36k, not sure if eligible for the TSB. I'll print it out and give it a try. Any suggestions or examples of people who've had success getting it done over 36k?
  6. Dec 7, 2008 at 11:06 AM
    dbkonkle
    dbkonkle Member
    Springdale, AR
    09 4x4 TRD Off Road
    Have you considered airbags to assist the factory leaf springs? A friend is using them on his 1/2 ton chevy to level it out when carrying his camper. He has the fill valve installed inside the gas cap cover and uses a 12 volt compresor to air them up. Just dump most of the air when not needed.
    Just an idea, if you don't have the camper on the truck all the time.
    David
  7. Dec 7, 2008 at 11:22 AM
    bajapescado
    camper is on 24/7. considered airbags, but like Timbrens, less maintenance.
  8. Dec 7, 2008 at 12:09 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    i've used timbrens on the front of trucks with snow plows and they worked very well and weren't noticeable without the extra weight. i have no experience with airbags but i have a friend with a f-150 and camper and he has bags on it
  9. Dec 7, 2008 at 12:23 PM
    pittim
    Pennsyltucky
    Boujee Prius
