Replacement led exterior lights.
Discussion in '3rd Gen. Tacomas (2016+)' started by Fye123, Sep 2, 2018.
  1. Sep 2, 2018 at 7:17 AM
    Fye123
    Fye123 [OP] Well-Known Member
    2016 SR5 access cab. 4x4
    Hi there, I am looking for some help from someone with first hand experience in a subject. I am looking to just replace the bulbs in all of my exterior lights to led, are you able to do that without replacing the ballasts? I just want to swap the bulbs, another concern I have is the when you swap led to these ballasts, that they do not warm up enough and you can run into problems with them icing over, I live in Minnesota.
    I appreciate any help with these questions. I just can't seem to find a definitive answer on here.
    Thanks!
  2. Sep 2, 2018 at 7:27 AM
    JoeCOVA
    JoeCOVA IG @MightyJoeFlannel
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    35" Trepadors w/ OMF Beadlocks, Kings, OBA, 5.29s etc
    what do you mean by ballast? The wiring harness? Ballasts only come with HIDs so you can just do a bulb replacement with LEDs.
    That said you may need to find some with resistors otherwise your turn signals will hyper blink, thinking a bulb is out.
  3. Sep 2, 2018 at 7:29 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    The only led lights that I know of which will require ballasts will be your headlights and fogs. The others should be just simple bulbs. Not sure about the bulbs having enough resistance to work properly.
  4. Sep 2, 2018 at 7:30 AM
    Fye123
    Okay then I an mistaken on the ballasts, thank you for clearing that up for me!
  5. Sep 2, 2018 at 7:33 AM
    JoeCOVA
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    LEDs don’t use a ballast. Only HIDs do. All LEDs are straight plug and play and sometimes come with a mountless in-line driver.
  6. Sep 2, 2018 at 7:38 AM
    HacksawMark
    Mark
    OREGON
    My XHP50 lights came with what looks like a ballast that connect to the LEDs. Is that for resistance?
  7. Sep 2, 2018 at 7:41 AM
    JoeCOVA
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    That’s an in-line driver which connects to factory wiring. Should be plug and play.
    Ballasts typically use an upgraded harness and wire in much differently. Battery to a harness, then the harnes with relay is wired to single factory harness, and the ballasts. Then bulbs are plugged into the ballast. Slightly more involved.
  8. Sep 2, 2018 at 7:47 AM
    HacksawMark
    Mark
    OREGON
    Cool! Thanks for the education!
  9. Sep 2, 2018 at 7:54 AM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
  10. Sep 2, 2018 at 8:08 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
  11. Sep 2, 2018 at 8:59 AM
    thedriza
    Portland, OR
    2017 Tacoma DCSB
    No hyperflash or strobing
    mattgecko likes this.
  12. Sep 2, 2018 at 9:36 AM
    Gary86
    Gary86 IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    And these are for the turn signals?
  13. Sep 2, 2018 at 9:53 AM
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    The one-star review on those is mine. Lasted a few weeks and died. They may be fine as turn-signal-only, but as DRL’s not so much. ymmv.
    Oh, and tried to contact the seller to get a replacement set. Nothing. Nada. Zilch. If you’re outside of the thirty day Amazon return window, you’re screwed.
  14. Sep 2, 2018 at 12:43 PM
    thedriza
    Portland, OR
    2017 Tacoma DCSB
    I used the Amber's for turn signals, and the whites as reverse lights.
  15. Sep 2, 2018 at 4:00 PM
    Rooster OG
    Rooster OG Well-Known Member
    Tom
    Northern California
    Cement 2018 TRD Off Road M/T
    I put led’s in my front turn signals and needed a resistor. The reverse and plate lights were plug and play.
