Replacement Shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by gudi82, Aug 4, 2010.
  1. Aug 4, 2010 at 11:08 PM
    gudi82
    gudi82 [OP] Member
    2000 Toyota Tacoma Ext. Cab
    I wanted to know what is the best shocks out there when you have a ARB winch bumber with a winch attached to hold up the front end and the rear?
  2. Aug 4, 2010 at 11:34 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    Is your truck lifted? or want to lift it if not?
  3. Aug 4, 2010 at 11:35 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    billstein 5100's or OME coil springs and some deavers for the back
  4. Aug 5, 2010 at 7:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW.
    With an ARB bumper and winch you've probably added a good 180-200 extra pounds on the front. Unfortunately, the stock Tacoma springs will sag under this much added weight.
    To overcome the sag you have several choices available. As mentioned by others, Bilstein makes a replacement shock that allows you to raise the front of the truck back up to stock height or even higher than stock. But that wont really fix the bigger problem. With an ARB and winch, replacing the front springs is the best option and while your doing that might as well replace the shocks.
    When AKTacoma asked if you were thinking lifting the truck higher that stock, it is because that is what you must decide first. Everything else flows from there. If your front springs are sagging, more that likely the rear springs are as well.
  5. Sep 4, 2010 at 9:06 PM
    gudi82
    gudi82 [OP] Member
    I was thinking to keep it stock for now.
  6. Sep 4, 2010 at 9:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you are asking the question I would guess that your front end is sagging. Possibly from the added weight of the bumper and winch.
    Is that why you are asking?
    Replacing shocks alone will not do anything. The shocks are not what holds up the front end. It is the springs that do that.
  7. Sep 4, 2010 at 9:29 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    The way I see it is you have 2 general price ranges that you can decide on:
    Good - Bilstein 5100's or Old Man Emu's
    Better - 2.5" or 3.0", adjustable, rebuildable coilovers (Sway-Away, Icon, Fox, etc.)
    Of course there's always long travel, but it doesn't sound like you want to spend that much money.
