Replacement Wheel Advise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Corn, Oct 31, 2018.
  1. Nov 1, 2018 at 12:19 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I was saying that the AR172 Baja in a 15x7 should stick out 3/4" further out from the stock OEM wheels.
  2. Nov 1, 2018 at 1:58 PM
    Corn
    Corn [OP] Well-Known Member
    NC
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights, suspension, wheels
    @boostedka
    Ok, thanks.
    I've got 31 x 10.5s on there. I know they are a little big (but it came with Wranglers that size at the dealer back in 2000). I never had any issues with the tires rubbing anywhere with the stock wheels, but the ones I have now made them hit the wheel well plastic...and I ended up installing new suspension all around anyway, and that took care of that.
    boostedka likes this.
  3. Nov 1, 2018 at 2:06 PM
    Corn
    NC
    @Danno1985
    Those look pretty good, great price. Would probably be fine since they are stock wheels (although older model). Thanks
  4. Nov 2, 2018 at 7:58 AM
    Corn
    NC
    It was a chore trying to figure out how much wheels would stick out/in, but I found this helpful website.
    For all interested:
  5. May 8, 2020 at 9:42 PM
    cyclist7
    cyclist7 New Member
    1999 Tacoma TRD Limited
    Hey there, just found this thread. I have a similar truck as @Corn and am looking to get the same wheels/tires setup you experienced the rubbing with (15x8, -19mm offset, 31x10.5r15). Do you remember where the rubbing was (front or back) and when it happened (turning, over bumps, etc.)? How much of a suspension lift did you get to solve the problem? Thanks!
