Replacements for my stock axle
Discussion in '4 Cylinder' started by 2TRunner09, Jul 12, 2020.
  1. Jul 12, 2020 at 4:29 PM
    2TRunner09
    2TRunner09 [OP] New Member
    09 Silver 2TR-FE 5speed 4x4
    Lce Engineering street header K&N 63 series Cai
    I have a 09 base with the 2tr and five speed. When i bought it the rear tires started cupping badly. Had it looked at by a few shops and everyone says the axle bearings seem good but the rear left tire has almost a degree of negative camber and slightly less on the right. Two different people have said my axle is bent and i need a complete housing but i find that hard to believe. Because my rear axle is only LSD i was wondering if there were any good options for mechanical lockers already built into a housing i can swap if i do have to pull the whole axle. Just looking for opinions, keep in mind i do my own work but know my limitations and don't have a lot of experience with troubleshooting something like this. Someone told me i should be able to get a shim kit but others say there isnt such a thing for a straight axle. Let me hear your thoughts
  2. Jul 12, 2020 at 7:22 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    is it a 1 owner ????
    could a prev owner have tweaked the rear off road rock crawlin ???
    whatstcp likes this.
  3. Jul 12, 2020 at 10:03 PM
    2TRunner09
    Had another owner before me and there is evidence he put big tires under it. Has cheap strut spacers in the front (for clearance) so it has just a little carolina squat. Originally i figured the toe was wrong because of the squat and causing my wear but there is no adjustment at all on the axle. Wouldn't you have to just about jump the thing to bend the axle?
  4. Jul 12, 2020 at 10:07 PM
    ROAD DOG
    FEW
    iv never bent 1 b4
    of course its a possibility..................folks love those 900HP Baja supertrucks
    if he bent the axle he might not know it
    im sure he woudlnt admit it
    good luck
  5. Jul 12, 2020 at 10:12 PM
    whatstcp
    whatstcp currently drunk so don't listen to me
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    Nah, it doesn't take much to bend the axle to the point where it can mess with the alignment. The fact that it's barely noticeable means that it's not going to be bent to the naked eye. It just means that the outside axle mounting surface can be bent just enough. My bet is on the previous owner fishtailing just enough to kiss a curb with the rear wheel. Or possibly getting tapped there by another car in a minor fender bender. Happens more often than you think.
  6. Jul 13, 2020 at 8:05 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    No way to adjust camber on a live axle. I didn't think 1 degree of neg camber would cause cupping, maybe extra wear on the inside of the tires but that's it. 1 degree is just barely enough that you can't see it with the naked eye. If the live axle housing is bent even slightly I think there would be some sign, maybe the paint on top is cracked/flaked or some gear whine due to axle misalignment with the ring/differential?
    Also check the shock absorbers, a bad damper can cause cupping on the tire tread.
    I didn't know the base models came with LSD.
