Replacing Carrier Bearing and U-Joints on my 1st Gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by hawhawkk, Oct 28, 2021.
  1. Oct 28, 2021 at 6:55 AM
    hawhawkk
    hawhawkk [OP] Member
    Joe
    2003 Toyota Tacoma Double Cab PreRunner 3.4L 2WD
    Hey all, I have been lurking for a while and am in need of some assistance.
    I am wanting to replace my carrier bearing and u-joints and need some help with resources on finding the correct parts to use. I'm new to this and want to take care of my taco, but I need some help.
    TIA!
  2. Oct 28, 2021 at 6:59 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    1997tacomav6 likes this.
  3. Oct 28, 2021 at 7:04 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
  4. Oct 28, 2021 at 7:39 AM
    1997tacomav6
    Denver
  5. Oct 28, 2021 at 7:42 AM
    hawhawkk
    Joe
    I went here: https://partsouq.com/en/catalog/genuine and searched by VIN
    and found the part number for the center support bearing: 3723035130
    and for the spider kit: 0437135051
    So per RockAuto it looks like I need the TIMKEN HB31 for center support bearing, and DANA 51510X for the U-Joints.
    Is that site I linked earlier to be trusted?
  6. Oct 28, 2021 at 9:08 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have a good drive line Guy He can change the U- joints cheaper then me. He rebuilds my double Cardan joints as well.
    I go with his choice of U- joints
    I don`t change enough to get around to building the correct jigs
  7. Oct 28, 2021 at 9:41 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I've never heard of the site you linked. The HB31 is listed as for the 4WD, the HB26 is for RWD, according to RockAuto anyway. The other manufacturers mostly have different parts for 4WD and RWD, so I am assuming they are slightly different. Your profile says you have a 2WD.
  8. Oct 28, 2021 at 9:59 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I don't understand why you're not looking at parts.toyota.com with your own vin number to verify part numbers for your own rig. It's easy to do and ensures that you're getting the right parts vs, hoping rock auto has their parts correct.
    Bivouac likes this.
  9. Oct 28, 2021 at 10:03 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I always buy the OEM bearings. I blew up a timken one in less than 1000miles and same with the cheapo spicer. The last OEM one I bought wasn't a spicer. I have another one coming this week as I crushed it on a rock and will verify it.
    The timken "rubber" is more of a hard plastic that basically ripped at a seam while on a road trip. Sucked I could only do 55mph for 11hrs.
  10. Oct 28, 2021 at 10:08 AM
    eon_blue
    Azusa, CA
  11. Oct 28, 2021 at 11:08 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    I need to purchase u joins also this is good info. I got the spicer support bearing with Amazon in it was legit stamp Toyota .
