Replacing fan clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, May 18, 2011.
  1. May 18, 2011 at 12:54 AM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    Can't seem to find any info here about the steps to replace one. Is it hard? Any help would be great.
  2. May 18, 2011 at 11:58 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
  3. May 19, 2011 at 3:54 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    bump n sub
  4. May 21, 2011 at 1:38 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    How do you move a topic? I want to move this to the Garage section.
  5. May 21, 2011 at 5:10 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    not to hard, 4 nuts, If I can remember correctly thet are 10mm
  6. May 21, 2011 at 7:57 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    4 nuts and the blades come off the clutch..then remove the clutch from the motor itself. It should be fairly easy.
  7. Jan 18, 2014 at 9:57 PM
    Vinyl Trooper
    Vinyl Trooper Well-Known Member
    Roy
    Los Angeles
    99 Tacoma 4WD
    Fabtech Suspension
    Thought I'd bring this back, since it's the only thread found with info about replacing the fan clutch.
    Has anyone done it? Is there a torque spec that I would have to go by?
  8. Jan 19, 2014 at 11:06 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I did it but I'm not sure about torque specs. I just tighten them down good and they have been fine for the last 3 years. It's a little tight getting in there but you can do it with only taking minium stuff off.
  9. Jan 20, 2014 at 11:26 AM
    Vinyl Trooper
    Roy
    Los Angeles
    99 Tacoma 4WD
    Fabtech Suspension
    Got it! Thanks for replying. Gonna do it today.
  10. Jan 21, 2014 at 11:01 AM
    Vinyl Trooper
    Roy
    Los Angeles
    99 Tacoma 4WD
    Fabtech Suspension
    Done! Thanks SlickyD.
