replacing HAVC fan?
Discussion in '1st Gen. Tacomas (1995-2004)' started by brelandt, Mar 13, 2012.
  1. Mar 13, 2012 at 7:22 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I am hearing a whirling noise when I turn my dash fan on anything above 2. In my past whenever this has happened it was just time to replace it. I have tried cleaning, oiling you name it on my other cars and the noise just starts right back up.
    Is the fan hard to get to in the Tacoma's? Super easy on the Civic and Integras I had years ago.
  2. Mar 13, 2012 at 7:29 PM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    do a search on chirp noise, all over this forum, from what I have read this is really easy less than 1 hr. wish u the best
  3. Mar 13, 2012 at 8:07 PM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    I cleaned mine on my 04 and it is a breeze to get out. Look under the dash on the passenger side. Look to the right and the fan mounts from the bottom. Three screws, if I remember correctly and the wire connection. You can take the glove box off to see better if you want to. Remove the two screws at the bottom of the glove box and there ya go.
    Here is a diagram from the FSM to give you a better idea. Scroll down a little.
  4. Mar 13, 2012 at 10:25 PM
    brelandt
    Terry
    Dublin, CA
    thanks guys looks as easy as the others I've done!
