Replacing JBL subwoofer? What fits?
Discussion in 'Audio & Video' started by jrdbrn, Dec 29, 2011.
  1. Dec 29, 2011 at 4:28 PM
    jrdbrn
    jrdbrn [OP] Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    OK, so I have the JBL package in my truck and the bass is low. If I wanted to add a little more thump, but keep it moderate, can I fit a subwoofer in it's place?
    It is a 20cm woofer, which converts to 8", right? Will something like http://www.jlaudio.com/10w3v3-2-car-audio-w3v3-subwoofer-drivers-92150 fit? I'd have to change the amp as well, right?
    I can install the units, but choosing, I am noob.
  2. Dec 29, 2011 at 4:34 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    Shallow mount would be better.
    http://www.amazon.com/Kicker-10cvt8-2-Shallow-Subwoofer-2-ohm/dp/tech-data/B003LAEJ9O/ref=de_a_smtd
    Size (IN.,CM) 8, 20
    Impedance (OHMS) 2 or 4
    Max Rec Amplifier Power (WATTS PEAK/RMS)* 400/200
    Frequency Response (Hz) 25-350
    Mounting Depth (IN.,CM) 3-3/8, 8.6
    Mounting Cutout (IN.,CM) 7-1/16, 17.8
    Min Rec Sealed Box Volume (CU. FT., Liters) .4, 11.3
    Max Rec Sealed Box Volume (CU. FT., Liters) 1.8, 51
    Min Rec Vented Box Volume (CU. Ft., Liters)** .8, 22.7
    Max Rec Vented Box Volume (CU. Ft., Liters)** 1.2, 34
  3. Dec 29, 2011 at 4:45 PM
    jasonvelocity
    jasonvelocity Well-Known Member
    Palmer Lake, CO
  4. Dec 29, 2011 at 4:50 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I'm interested in this, not for more, just for a replacement down the road. Whenever the sub blows I want to replace it with a more durable one and not spend a fortune that Toyota will charge for the replacement.
  5. Dec 29, 2011 at 5:17 PM
    TacoDawgfan
    Georgia
    That is the dilemma, hate to go back stock but don't want something the amp cant push.
  6. May 8, 2012 at 4:42 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    TTT. How big is the stock amp? 8" seems crazy small.
  7. May 8, 2012 at 4:48 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    where are these stock subs located in a doublecab, ive never seen them before, kinda curious
  8. May 8, 2012 at 4:49 PM
    Aw9d
    Aw9d That one guy
    just one sub, behind rear passenger seat.
  9. May 8, 2012 at 7:21 PM
    03f5sp
    Bill
    Wisconsin
    How many watts is the stock amp?
  10. May 8, 2012 at 7:33 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I've learned this little thing bumps well if you listen to a disc or through the AUX.
    Can't even tell it's there with the radio.
    Jomabago and TacoTuesday!! like this.
  11. May 8, 2012 at 7:40 PM
    03f5sp
    Bill
    Wisconsin
    Found it. 45 watts to the sub. Hopefully it's loud enough with some minor changes. I've currently got 2 12" with 400 watts turned up about 1/4-1/3.
  12. May 9, 2012 at 1:35 PM
    lakerfan
    lakerfan Well-Known Member
    Doug
    Castaic,CA
    09 DBL CAB PRERUNNER SPORT,Mag Grey.
    Sway away 2.5 coilovers, Maxtrac spindles, Dakar rear leafs, 18x9 Moto metals.
    90 watts to the sub,and 45 watts to each door.
  13. May 13, 2012 at 1:05 PM
    03f5sp
    Bill
    Wisconsin
    Is the JBL Audio only available in the 4 door?
  14. May 13, 2012 at 1:10 PM
    TacoDawgfan
    Georgia
    I think it sounds great with sat. or ipod. But many on here hate on it. I've even gotten negative rep for saying I like it. I guess that means I have to go all out with an aftermarket set up even though I'm happy with it. :rolleyes:
  15. Mar 17, 2016 at 4:01 AM
    AutoEntropy
    AutoEntropy Bonafide Lover
    Jaeger
    Tempe, AZ
    2014 Tacoma V6 Sport 4x4 4dr Super White
    Method Mesh Wheels 17X8.5 Offset 0 Spacing 4.75" BF Goodrich All Terrain TA KO2 265/70 R17 Factory Roof Rack Factory Bed Net
    Did anybody ever figure out if its 45 or 90 to the sub behind the back seat? Anybody know if there is a better sub to replace it with?
  16. Mar 17, 2016 at 6:46 AM
    dmb1650
    dmb1650 Well-Known Member
    2012 Blk Tacoma TRD sport DCLB
    Another problem I could see is that the JBL digital sound processor most likely limits its output. There's probably a point where sub output stops increasing even if you turn the volume up more. This is done to protect the sub so Toyota isn't replacing them under warranty. A different sub might give more output but the result would be marginal. Also you would need to match the sub woofer impedance. The JBL website says dual voice coil sub but you would need to measure the factory amplifier impedance to match up a replacement.
    If you really want more output I would look for suggestions on how to add an aftermarket subwoofer and amp to the factory JBL system. I know members have installed one of these http://www.jlaudio.com/cp108lg-w3v3-car-audio-microsub-subwoofer-systems-93133 without having to modify much(I think no modifications at all). They also make one with an amplifier built into the box which should also fit behind the seats. As far as getting a signal from the factory system I am unsure since I don't have the JBL in my truck.
  17. Mar 17, 2016 at 7:02 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Impedance is determined by the driver - not the amp. The amp operates to an acceptable minimum impedance load, but the driver determines that value.
  18. Mar 24, 2016 at 6:01 PM
    eddiet215
    eddiet215 New Member
    Eddie
    2013 White Tacoma TRD Racing
    Can you switch the stock amp with an after market amp?
  19. Mar 27, 2016 at 5:23 PM
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    Nope. You will get no sound. You can add the amp after the jbl amp and it will work fine.
  20. Aug 12, 2017 at 5:49 PM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    Is the jbl amp stable at 4 or 2 ohm? The reason being, I ordered the pioneer 8" DVC 2ohm to replace the blown stock. I just don't want to fry this jbl amp.
