Replacing JBL subwoofer? What fits?
Discussion in 'Audio & Video' started by jrdbrn, Dec 29, 2011.
  1. Aug 14, 2017 at 5:56 PM
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    I believe the jbl amp is 2 ohm. It should work fine. I took mine out and replaced it with a RF 2 ohm 8 inch punch with no problems.
    Javier22 likes this.
  2. Aug 14, 2017 at 11:25 PM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    Thanks bear. I really appreciate your reply. I picked up a pioneer 8 dvc 2 ohm.
  3. Aug 15, 2017 at 6:23 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
  4. Aug 15, 2017 at 11:18 PM
    m_yota
    Paradise
    08 4x4 dbl cab
    Just hooked up my newly arrived pioneer slim sub. Great improvement. Solid bass response. I just had to configure the sub wires.
    TacoTuesday!! likes this.
  5. Aug 16, 2017 at 11:06 AM
    AH99
    AH99 New Member
    Did you use the stock amp?
  6. Aug 16, 2017 at 4:27 PM
    m_yota
    Paradise
    08 4x4 dbl cab
    Yes, I used the stock amp. With only the sub replacement, sound is very noticeable and bass response is !
  7. Aug 16, 2017 at 5:27 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Alpine's Jim Walter says these are way underrated - by a factor of 2 or more. That said, they do tend to shed surrounds at some level of abuse. Keep it just under that :thumbsup::p
  8. Jan 22, 2018 at 11:25 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Do you have a link for which sub you bought ?
    Batman! likes this.
  9. Jan 23, 2018 at 10:22 PM
    m_yota
    Paradise
    08 4x4 dbl cab
  10. Jan 24, 2018 at 10:13 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thanks man!!
  11. Jan 24, 2018 at 10:34 AM
    grichg
    grichg Well-Known Member
    rich
    Laguna Beach
    11 Tacoma 4x4
    Camburg 3.0 Coilovers Camburg A-arms All Pro rear bumper CBI Front Bumper LED Light Bar and PODs and some other misc
  12. May 5, 2018 at 11:47 AM
    Fr33Ma$on
    Fr33Ma$on Well-Known Member
    Eastern Washington
    2006 Indigo Ink Pearl TRD Sport Tacoma
    Audio newbie here, what would happen if I put a 4 ohm in with stock amp? Looking for a sub to replace blown out stock one also.
  13. May 6, 2018 at 5:51 AM
    bear263
    Florida
    Either would work. I started with a 2ohm that had no problems and then moved to a 4ohm. In theory a 4ohm would be better so when you hook it up in parallel, it'll be 2ohm.
    Somone can correct me if I am mistaken.
  14. May 8, 2018 at 6:49 AM
    Twitch81
    Twitch81 Well-Known Member
    2019 Double cab Taco 4x4
    Was the pioneer much better than the stock sub?
  15. May 23, 2018 at 10:06 AM
    #35
    Brandon230
    Brandon230 Active Member
    2018 Blazing Blue Pearl Tacoma Limited
    None yet...looking at options
    Did you ever get an answer? I am curious as well.
  16. May 23, 2018 at 10:07 AM
    #36
    Twitch81
    Negative
    Brandon230 likes this.
  17. Jun 27, 2018 at 10:36 AM
    #37
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Digging this up from a couple pages back. It want to clarify for any others who stumble upon the info.
    The amp is said to be stable to 2ohm. Therefore for optimal output, you want either a 2ohm sub of DVC 4ohm or DVC 1ohm. DVC subs must be either wired in series or parallel either doubling or cutting the impedance (ohm measurement) in half.
    So a DVC 2ohm would leave you running at either 1ohm (you'll fry the amp) or 4ohm (run the amp at 1/2 the wattage output vs it's 2ohm rating.)
  18. Jul 11, 2018 at 1:46 PM
    #38
    kharazmatik
    kharazmatik Active Member
    Benja
    Maui,HI
    00 PreRunner
  19. Aug 19, 2018 at 7:57 AM
    #39
    bwavery
    bwavery New Member
    2018 black Tacoma TRD Sport
    I just purchased a new Sport with the JBL system and really find it lacking like most on this string. I noticed on this post some success replacing their JBL speakers, would be great to know some details, how the new speakers are working, and if you have any photos of your install. Be great to see some details on replacing the JBL sub, with photos if anyone has any. Lots on non-JBL, but not on the JBL. I keep checking OEM Audio Plus and Taco Tunes but no luck.
    badhabit2break likes this.
  20. Aug 23, 2018 at 7:14 AM
    #40
    bwavery
    bwavery New Member
    Just curious how the replacement is going, thinking of upgrading the sub in my 2018, also do you notice any real different? I would suspect, but never really know. Did you have to do much to get the new speaker compatible with the wiring harness? thanks.
