Replacing LCA help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dant123, Sep 25, 2016.
  1. Sep 25, 2016 at 7:29 AM
    dant123
    dant123 [OP] Member
    2007 tacoma
    My LCA bushings are complete toast. So I am replacing the entire LCA with moog. The advantage I see in this is fresh bushings and ball joints already pressed into place. I have all my parts and am ready to rock and roll. But if anyone has any suggestions fire away. Mostly I want to find the specs for the ftlbs required on all the bolts. I know the camber /caster bolts are supposed to be torqued to like 125, or 140 or something. But what about my ball joints and the bolt holding the spring to the LCA? Any help or resources are much appreciated!
  2. Sep 25, 2016 at 7:44 AM
    Crazydave
    Crazydave Crazy Dave
    Dave
    Western PA
    2015 Tacoma SR5 DCLB
    265/75R16, Clazzio seat covers W/aftermarket heated seats, Interior lights changed to LED
  3. Sep 25, 2016 at 8:45 AM
    dant123
    dant123 [OP] Member
    2007 tacoma
    Thanks crazydave!! That's exactly what I needed, just wasn't sure where to look
    Crazydave likes this.
  4. Sep 25, 2016 at 8:49 AM
    dant123
    dant123 [OP] Member
    2007 tacoma
    But actually these three numbers are confusing me in the sheets. Is it that third number that is the ft lbs?
