Replacing parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tonybar1, Apr 2, 2025.
  1. Apr 2, 2025 at 4:01 PM
    Tonybar1
    Tonybar1 [OP] New Member
    Tony
    2004 Tacoma 2.7L 4x4 5SPDMT
    I recently got a 2004 2.7L 4x4 5SPDMT Tacoma with 179K and was compiling a list of parts to replace soon.
    (2) Front Sway Bar Links
    (2) Front Lower Ball Joints
    (2) Front Outer Tie Rods
    (2) Front Upper Ball Joints
    (2) Front Inner Tie Rods
    (2) Front CV Axle Assemblies
    (2) Front Wheel Hubs
    (2) Front Wheel Bearings
    (4) Front Wheel Seals
    Is there anything else I should purchase while I'm at it?
    Brakes are good and I was planning on getting the harder to reach fluids inspected soon. Thanks!
  2. Apr 2, 2025 at 4:07 PM
    Blakeus Maximus
    Blakeus Maximus Well-Known Member
    Southwest
    2000 TACOMA TRD 4X4
    Upper and lower control arm bushings, or the upper and lower control arm assemblies with bushings. Steering rack bushings.
  3. Apr 2, 2025 at 4:22 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    I had original shocks at 265k. 3 months ago I installed new shocks (4600's) on all 4 corners and it was good money spent. If I drop any bucks I wanna see results, and I will say I did see great results and it was way worth it.
    ztwatson likes this.
  4. Apr 2, 2025 at 4:23 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Welcome to TW. Personally I wouldn't do inners, if it needs inners I would just replace the rack. For the next question see attached. :-D Not everything on your list is in there but will give you a good idea of price comparison.
  5. Apr 2, 2025 at 4:35 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    The only thing on that list I would do without symptoms of a problem would be lower ball joints. Unless you are having issues there is no point to replace those parts, especially the front bearings, cv axles and inner tie rods. For example, the common wisdom is that Toyota CV axles are superior to off brand. So if you were thinking of using off brand axles, you’d likely just be downgrading for no reason.
    skeezix and Moonrman like this.
  6. Apr 2, 2025 at 5:13 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Welcome!!!!!!!
    wealth of knowledge/experience/willingness to assist here at every level
    that’s how I got thru my 9 month maintenance “rebuild” of my….I mean….kids taco
    make sure u use that Search feature!!!!
    Killer info out there
    Moonrman and Black97v6MT like this.
  7. Apr 2, 2025 at 7:00 PM
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
    That’s a good lookin truck.
    Get the good LBJ bolts, the black ones with the washers (90119-10933). And make sure to use the correct torque spec for those, 37ft lbs iirc.
    And I’d do all the fluids for sure. If you’re so inclined, grab Lexus front diff drain (90341-24016) and fill (90341-18060) plugs to replace the easily strippable socket heads with hex heads
    Lugnutz and ControlCar like this.
