Replacing U-Joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by BigD20, Mar 10, 2010.
  1. Mar 10, 2010 at 3:50 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    Hey guys..so I have this squeak under my truck and I'm guessing it's either the U-joints or the center support bearing. Since the U joints are fairly easy to replace I'm going to go ahead and do that and see if it takes care of the problem. This will be my first time attempting to replace my U joints..is there anything special I should know? I know I need to mark the position of the drive shaft and yoke. Anything else? Thanks
  2. Mar 10, 2010 at 4:06 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you lubricated the U-joints lately? That alone might get rid of the squeek.
  3. Mar 10, 2010 at 5:00 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    Yes I have lubricated them and the squeak is still there..so I'm going to see if replacing the U joints will take care of the problem
  4. Mar 10, 2010 at 6:12 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    are there any certain torque specs that the bolts that connect the drive shaft to the differential need to be?
  5. Mar 10, 2010 at 8:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Have you checked U joints for play or movement by grabbing the driveshaft at the point of connection (front & rear) & check for side to side movement ?
  6. Mar 11, 2010 at 1:49 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    X2 You can usually check your U-Joints by twisting the driveshaft and feeling how much "play" is in them. If it feels loose they should probably be replaced. If everything feels tight, then you have another problem to look at. Start by greasing every grease zerk you can find...
  7. Mar 11, 2010 at 3:19 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    I fixed the squeak. It was the rear U joint on the rear drive shaft. It was squeaking like crazy. Glad I put on end to that! Thanks for all the advice!
