Research For Tie Down Rail System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CAPITAL_ROB, Dec 4, 2007.
  1. Dec 4, 2007 at 10:05 AM
    CAPITAL_ROB
    CAPITAL_ROB [OP] Member
    CHATSWORTH
    STOCK TACOMA JUST GOT IT
    JUST A TIE DOWN BAR I MADE FOR MY SPORTBIKE FOR NOW. LOOKING INTO TURBO
    Hey, I Am New Here And Have Already Introduced Myself, What I Was Wondering Is, If A Tie Down System Was Available For The 2005 To 2007 Tacoma. Would People Be Interested, The Reason I Asked Is I Came Up With Something That Bolts To The Bottom Of The Bed And Is Mainly Used For Motorcycle Tie Down And Is 1000% Stronger Then The Rail System That Comes With The Truck, You Can Also Use The Canyon Dancers With It. So I Would Like Some Feed Back To See If I Should Market This Product....or Is There Something Else Available ?
  2. Dec 4, 2007 at 10:16 AM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    Have any pics?:rolleyes:
  3. Dec 4, 2007 at 10:17 AM
    CAPITAL_ROB
    CHATSWORTH
    I SHOULD BE GETTING SOME LATER TODAY....I AM JUST TRYING TO FIND OUT IF IT'S SOMETHING THAT CAN BE USED OR EVEN WANTED
  4. Dec 4, 2007 at 10:18 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'd be interested in hearing more about it. Literally 1000% stronger? Or just a whole lot stronger?
  5. Dec 4, 2007 at 10:19 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    If there is a market for steps for a short dog to get on a tall bed, there is a market for anything. I'm sure you will find some people would be interested.
  6. Dec 4, 2007 at 10:43 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    How would this be different than the D rings in the bed floor?
  7. Dec 4, 2007 at 11:01 AM
    CAPITAL_ROB
    CHATSWORTH
    WELL THE "D" RINGS ONLY CONNECT TO A SMALL AREA. MY SYSTEM HAS STEEL ON BOTH SIDES OF THE BED, TOP AND BOTTOM.
  8. Dec 4, 2007 at 12:55 PM
    CAPITAL_ROB
    CHATSWORTH
    Here Are Some Pics
  9. Dec 4, 2007 at 1:00 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    looks like a good idea it would work good for an atv
  10. Dec 4, 2007 at 1:02 PM
    CAPITAL_ROB
    CHATSWORTH
    I USE IT FOR A 2005 HONDA CBR600RR TRACK BIKE. I CAN PUT 2 BIKE BACK THERE WITH THIS SYSTEM. I DON'T KNOW ABOUT AN ATV BECAUSE I DONT HAVE ONE.........YET.....
  11. Dec 4, 2007 at 1:02 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Looks good, but I only haul my bicycles...
  12. Dec 4, 2007 at 1:03 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'd think about going in for the rear suspension TSB if you haven't done so already.
  13. Dec 4, 2007 at 1:07 PM
    CAPITAL_ROB
    CHATSWORTH
    WHAT IS THAT TSB...I WAS TRYING TO FIND IT HERE
  14. Dec 4, 2007 at 1:11 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    They replace your rear leaf springs for ones with an extra leaf. If you have the non-TRD, they give you Bilstein shocks all around.
  15. Dec 4, 2007 at 1:22 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Looks good, but I did something myself so don't really need it... So far 6 D-rings has been enough for everything I do, and I still have 2 more bed bolts if I want to add another set.
  16. Dec 4, 2007 at 1:37 PM
    CAPITAL_ROB
    CHATSWORTH
    LOOKS GREAT
  17. Dec 4, 2007 at 1:39 PM
    CAPITAL_ROB
    CHATSWORTH
    YES, I HAVE THE NON TRD TACOMA 2 WHEEL DRIVE 4 CYLINDER 2007.
    SO WHAT DO I NEED TO DO TO GET THEM TO DO IT....I JUST LOOKED AT MY MITCHELL MANAGER PROGRAM AND I HAVE NOT SEEN ANYTHING FOR REAR SUSPENSION TSB....
  18. Dec 4, 2007 at 1:43 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Thanks! I had to modify them to fit. (bored out the hole to fit the bolts, and trimmed the washer on the bolt to fit around the ring) They were called "rope rings" on a trailer supply store, only $1 or so each. So I'm sure you could modify them, or get them made to fit and market it for less than the toyota add-a-ring set ($40 IIRC) that goes on the sides of the bed with backing plates.
    Other people on toyotanation have done the same thing, and one person found stainless steel ones he modified as well. I'm sure there would be a market for people that don't want to or can't modify them to fit.
    Or post up what you've come up with over there as well. Lots of people with bikes are looking for better tie downs.
  19. Dec 4, 2007 at 1:46 PM
    CAPITAL_ROB
    CHATSWORTH
    THE REASON I MADE MINE THIS WAY IS SO I CAN FIT 2 BIKES BACK THERE. MIN TOO HAS METAL UNDER THE BED FOR ADDED STRENGTH. IF I WAS TO SELL IT, IT WOULD BE A KIT INCLUDING INSTRUCTIONS AND A 1/2 INCH DRILL BIT
  20. Dec 4, 2007 at 2:43 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Nice! So it has a solid bar under the bed? That's cool! I didn't do the Toyota kit for price, and the fact I was worried the bed would crack. So I just used the bolts that hold the bed to the frame. If those crack or come out I have bigger problems! :D
    You're solution would be great for people without an air compressor, impact wrench, and #45 or #55 (i forget which) Torx bit for it. Nothing less than an impact wrench would take out the bed bolts on my truck.
