Resetting factory tpms?
Discussion in 'Wheels & Tires' started by jetmagnum, Oct 29, 2009.
  1. Oct 29, 2009 at 7:38 AM
    jetmagnum
    jetmagnum [OP] Well-Known Member
    NEW JERSEY
    09 TRD SPORT
    I just mounted 285's on my stock 17" rims. Tried to go throught the recalibration procedure in the owners manual but its not working. When i turn the key to the "on" position the light just blinks for like 20 seconds....
    Help?
  2. Oct 29, 2009 at 7:58 AM
    ramjm_2000
    ramjm_2000 Well-Known Member
    NoVa (Alexandria VA)
    08 PreRunner SR5 DoubleCab BSP
    5100's Rear TSB Dominator slider/step bars Eclipse AVN 2210 Nav/XM Leather Upgrade TRD Skid Century Royal Sheel Armor Tech Custom Rear Bumper
    Could one of the TPMS units have been damaged during install? I've heard of several folks having that problem. Goodluck
  3. Oct 29, 2009 at 8:05 AM
    jetmagnum
    NEW JERSEY
    09 TRD SPORT
    None of the sensors were visually damaged, how would i tell if they were damaged internally?
  4. Oct 29, 2009 at 8:23 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Did you check the spare tire pressure also? I believe the dealership can run some sort of scanner to see if one is defective.
  5. Oct 29, 2009 at 8:26 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    09's dont have the tmps on the spare, most likely your sensors need to be reprogrammed....
  6. Oct 29, 2009 at 8:28 AM
    jetmagnum
    NEW JERSEY
    09 TRD SPORT
    How do i reprogram them?
  7. Oct 29, 2009 at 8:35 AM
    eordonez
    Ed
    Chihuahua, Mexico
    dealership....
  8. Oct 29, 2009 at 8:37 AM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    News to me.
    Respectfully, where did you get that information?
    09 TRD Sport
  9. Oct 29, 2009 at 8:42 AM
    eordonez
    Ed
    Chihuahua, Mexico
    I think i read it somewhere around this place, and the toyota service guy told me also... of course i trust more the info on this site than a toyota service guy... :D
  10. Oct 29, 2009 at 8:43 AM
    eordonez
    Ed
    Chihuahua, Mexico
  11. Oct 29, 2009 at 8:54 AM
    geolink
    SILVER STATE
  12. Oct 29, 2009 at 8:57 AM
    eordonez
    Ed
    Chihuahua, Mexico
    yeah, if it has the metal stem with a nut, then its a tmps, strange that you have it
  13. Oct 29, 2009 at 9:03 AM
    geolink
    SILVER STATE
    Strange, yes.
    Maybe not having that tire "sensed" would be better.
    Must have been some thought behind that decision.
    Have a good day!
  14. Oct 29, 2009 at 9:19 AM
    jetmagnum
    NEW JERSEY
    09 TRD SPORT
    Ok, so since my tpms light just blinks it means that the system needs to be reprogrammed. The only way to do this is at the dealer? Is this correct?
  15. Oct 30, 2009 at 4:09 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    If it blinks that means one of them is damaged, if it has been damaged and repaired at a tire shop then it could need to be reprogrammed at the dealership....basically blinking TPMS= visit to dealer.
  16. Oct 30, 2009 at 5:45 AM
    Gingrbredman
    Gingrbredman Love the Tick!
    G
    Chicagoland
    09 Double Cab Sport 4WD
    Its funny that tire shops cant reprogram these. Discount Tire and places like that sell the TPMS with new tires. Why sell them in the new wheels if they can't program them?
  17. Oct 30, 2009 at 6:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2. Mine is blinking on the Tundra. It came on at 85K give or take. They have batteries in them. It could be just that simple.
  18. Oct 30, 2009 at 11:37 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i have a 09 dc 4x4 sport, no tpms on spare on my truck.
  19. Oct 30, 2009 at 11:41 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    i know some guys put all 4 tpms sensors in the spare tire.
  20. Oct 30, 2009 at 11:45 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    yes dealership can scan each sensor,it tells you sensor id numbers,actual tire pressure,temperature,and battery life.:D
