Resetting factory tpms?
Discussion in 'Wheels & Tires' started by jetmagnum, Oct 29, 2009.
  1. Oct 30, 2009 at 11:49 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    did you use the sensors that were on the truck or did you get new sensors?new sensors will need programmed at dealership,tpms sensors have id numbers that are programmed into the tpms unit.
  2. Oct 30, 2009 at 2:09 PM
    rockbug63
    rockbug63 Active Member
    central coast CA
    '09 Dbl cab 4x4 SR5 tow pkg.
    Rear leaf and steering column chatter tsb blower mtr replaced(waste of time) 2nd blw. mtr.; new headlights from DRL melt issue new water pump9 leaking0around block) pwr steering rack leaks, right frt. wheel bearing bad.
    Most new vehicles have the ability to sense a signal from a sensor that has been replaced without a trip to the stealer, even my sons cheap Kia since a tire shop recently broke one and replaced for free as they should have, and no problems,reset it self in a few miles. The Toyota design people made sure you had to pay a price when you replace one.
  3. Oct 30, 2009 at 6:37 PM
    jetmagnum
    jetmagnum [OP] Well-Known Member
    NEW JERSEY
    09 TRD SPORT
    Let me ask you this....i only have 7500 miles on my truck. Can the dealer void my warranty if i bring my truck in to reprogram my sensors and they see oversize tires and suspension modifications??
  4. Oct 31, 2009 at 1:08 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    No....check out the Magnuson-Moss Warranty Act
    http://en.wikipedia.org/wiki/Magnuson–Moss_Warranty_Act
  5. Oct 31, 2009 at 5:10 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    I've got snow tires and wheels inbound from Discount Tire. They told me they have the equipment to reprogram the truck for a new set of sensors. Since these have been on Toyotas since '06 and they sell tires all day long and that's all they do, I presume they know what they're talking about. (Time will tell. ;) ) They will also reprogram (if necessary) every time I swap tires for no charge. For that matter, I think they will swap tires and rebalance if I ask at no charge. It would surprise me if other tire/wheel shops didn't have the same capability.
