Resetting oil change warning lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leigh, Jun 16, 2012.
  1. Jun 16, 2012 at 8:19 AM
    Leigh
    Leigh [OP] Member
    Leigh
    Upstate New York
    09 Tacoma 2.7 litre
    I have searched the owner's manual, the forums to no avail. Does anyone know how to reset the oil change warning lights on a 2009 Tacoma 4x4 manual shift? I put in synthetic oil just after buying the truck with 35K miles on it, and the lights just stared about 200 miles later. Is there a way to set the alarm for 7K miles for synthetic oil?"
  2. Jun 16, 2012 at 8:55 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    This is from another thread and I have used this method before to reset mine. I dont think there is a way to change the alarm. I believe it is automatically set to 5K miles.
    After changing the engine oil (U.S.A. only)
    The oil change system should be reset. Perform the following procedures:
    Turn the engine switch off with the odometer reading shown.
    (→P. 157)
    Turn the engine switch to the ON position while holding down the
    trip meter reset button.
    Continue to press and hold the button until the odometer displays
    000000.
    If the system fails to reset, the light will continue flashing
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/200968-maintenance-light.html
  3. Jun 16, 2012 at 11:26 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    This, with my 11 I had to use the Trip A odometer though. Took me 2 tries but I got it, shouldn't be hard for you.
  4. Jun 16, 2012 at 12:02 PM
    JustMe
    JustMe Active Member
    2009 owner's manual, page 361. I guess you didn't look in the do-it-your self oil section of the manual.
  5. Jun 16, 2012 at 3:34 PM
    Leigh
    Leigh [OP] Member
    Leigh
    Upstate New York
    09 Tacoma 2.7 litre
    Thanks for the reference!!!
