Resetting tire pressure sensors
Discussion in 'Wheels & Tires' started by ap53, Sep 17, 2008.
  1. Sep 17, 2008 at 4:53 PM
    ap53
    ap53 [OP] Well-Known Member
    Art
    NJ
    06 PreRunner
    I just installed new tires and I can't reset the sensors, I press the reset button light blinks 3 times and it stays on, Is there something that I’m missing?
  2. Sep 17, 2008 at 5:14 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I don't want to steer you in the wrong direction, so just check your manual out it has it in there. Are you having to run a different pressure in your new tires than your spare?
  3. Sep 17, 2008 at 5:27 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    its either getting pressures out of spec w/ the stockers....or they broke one of the sensors...RTFM for light sequences to see what it is
  4. Sep 17, 2008 at 5:56 PM
    ap53
    Art
    NJ
    06 PreRunner
    All tires have 40 psi's I will check the spare, I’m thinking they broke the sensor too but I’m not sure. Is there a way that I can check with out taking the tires out.
  5. Sep 17, 2008 at 6:36 PM
    The_Hodge
    SC
    i dont think so....but if they broke the sensor, its definately their place to replace it. i'd have toyota look at it under warranty, but if its broke, i'd make whoever changed them fix it if its broke
  6. Sep 18, 2008 at 4:06 PM
    ap53
    Art
    NJ
    06 PreRunner
    Spare tire had 20 psi’s I added air in to the spare, problem solved,
    Thanks,
  7. Sep 19, 2008 at 4:15 PM
    smoknsal
    smoknsal Member
    My local tire shop has a tire sensor scanner, they told me exactly which one was bad. Now, I need to know, is there a difference between a steel or alloy wheel sensor.
