(RESOLVED, T-SB-0148-16) Uninitiated trip meters reset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by swimmer, Nov 6, 2015.
  1. Dec 14, 2015 at 12:18 PM
    #61
    swimmer
    swimmer [OP] Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Yes
  2. Dec 14, 2015 at 5:32 PM
    #62
    mxwrench
    mxwrench Well-Known Member
    Brian
    Hi Desert, So Cal
    2016 DCSB TRDOR 4X4 JBL SW
    FYI, mine did it again this morning. 3875 mi. Filled up Friday, truck sat all day Sunday. This morning Trip A=0 Trip B=0, and it was displaying the ODO on startup, which I find is always the case after this has happened (It's how I know it has happened because I always leave it displaying Trip B). So this is the 4th time for me. I also have had 4 instances of the speedo react slowly, like the second hand on a watch, tic, tic, tic. This problem however seems to be a bit more rare. I am due to have the hood looked at tomorrow by the Toyota field rep, so I will be sure to add this to the list. If I gain some traction on these issues with Toyota I will be sure to post relevant info here.
    Cornhuskers79 likes this.
  3. Dec 17, 2015 at 8:30 PM
    #63
    mxwrench
    Brian
    Hi Desert, So Cal
    Just as I expected. The Field service tech took the truck for a 30 mi test drive and found no abnormal function of the odo or trip meters. Also no indication of the odo needle ticking slowly like the second hand on a watch. An issue like this really needs to be in a modal failure before it can be properly diagnosed. Unfortunately, Toyota cannot be expected to replace gauge clusters at a whim when a customer has a complaint that cannot be verified. I'm sure they ain't cheap!
    So, I will continue to keep an eye on it, and hopefully they will catch the problem in the future and offer a Service Bulletin for a repair.
  4. Dec 17, 2015 at 10:40 PM
    #64
    RobPaul
    RobPaul Choose Goodness. Have Discretion.
    Rob
    Northern California
    2016 TRD Sport
    Mine just did it again this morning. I'm at 1371 miles. After just a 2 hour stop, both Trip A and Trip B went to zero!
  5. Dec 19, 2015 at 3:30 PM
    #65
    swimmer
    Tucson
    2016 TRDORAC4WD
    Mine did it again. First time to n about 2k miles. 3rd time overall. Filled up with gas. Drove about 5 miles, parked for about an hour and it went to odometer on start up (I always have trip A showing). Scrolled to trip A and B and both were zero. I've been writing down my odometer reading at each fill as a backup.
    For others having this issue, do you have your DRLs switched on when this has happened?
  6. Dec 19, 2015 at 8:25 PM
    #66
    Cornhuskers79
    Cornhuskers79 Well-Known Member
    Mine are always on.
    Not sure if it is dumb luck, but I got mine to go again after an aggressive turn.
  7. Dec 20, 2015 at 1:55 PM
    #67
    swimmer
    Tucson
    2016 TRDORAC4WD
    Mine did it again today. Are others with this issue seeing any kind of a correlation with fuel level and this occurring? Is it more often happening with a near full tank?
  8. Dec 22, 2015 at 7:58 AM
    #68
    Shellshock
    Iowa
    Mine just did it for the first time yesterday. Headlights were on and also the low fuel light sign about 30 miles remaining. It reset everything to zero and the low fuel light went off then came back on after a minute or two. This was all after making a bunch of short trips, so I turned the truck off and on quite a few times.
  9. Dec 22, 2015 at 8:18 AM
    #69
    swimmer
    Tucson
    2016 TRDORAC4WD
    So it seems not related to a near full tank. Not to sound like a broken record but, please call Toyota Customer Care and tell them what happened.
  10. Dec 22, 2015 at 8:33 AM
    #70
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    @swimmer can you start a poll or update first post to keep track of number of cases this is happening to and what grade truck (i.e. - SR5, SPORT, etc.)?
    Also if someone could get a video, that would be awesome.
    ericsan777 likes this.
  11. Dec 27, 2015 at 7:34 AM
    #71
    Tundravt
    Tundravt Member
    Art
    2016 Tacoma
    none
    Third Time this morning. Filled it day before. Less than 15 miles on Trip A. Will call Dealer and set up an appointment. Any body have any ideas what the problem is ? Previous Tank had no issues. Really Weird. Thanks
  12. Dec 29, 2015 at 10:02 AM
    #72
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    This just happened to be last night
  13. Dec 29, 2015 at 4:47 PM
    #73
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    I have a simple solution for you all. I just got my truck back from service / warranty issues. They likely disconnected my battery for the one service and I got in and saw everything was reset in regards to only the trip meter and the home page button I set. So as stupid as this sounds, check your battery terminal connections. Perhaps you have a loose one.
    It's the only 2 things I noticed that was reset so I just assumed that's the reason. If you moved your home button (the one on the right that looks like multiple pages) see if that happens to default to the speedo / distance left screen.
  14. Dec 29, 2015 at 5:13 PM
    #74
    crankb8tr
    crankb8tr Member
    Trip A & B reset Saturday afternoon without in put from me. Approximately 2600 miles on vehicle. Everything else seems to be functioning as designed.
  15. Dec 29, 2015 at 5:16 PM
    #75
    Wraith600
    Go and check your battery terminal connections and let us know if they were even slightly loose.
  16. Dec 30, 2015 at 9:08 AM
    #76
    Shellshock
    Iowa
    Checked mine and they are tight. No movement at all.
    Wraith600[QUOTED] likes this.
  17. Dec 30, 2015 at 4:33 PM
    #77
    swimmer
    Tucson
    2016 TRDORAC4WD
    FWIW, my truck went in for its 5k service a couple days ago. Since my truck had done the trip meter reset again since the last time the dealer saw my truck I mentioned to them it happened again. The looked into it. The checked for loose connections within the cluster itself, etc.. and found nothing. They contacted Toyota (again) and opened a case file. One thing the person at Toyota wanted to know was whether or not the Ecco settings/info also reset. I could not answer this as I pretty much never look at that. If I have a reset happen again I will check this.
    Does anyone know if your Ecco info also cleared when you had a trip meter incident?
  18. Dec 30, 2015 at 5:01 PM
    #78
    Shellshock
    Iowa
    The in dash display that shows distance to empty and fuel economy was reset on mine. After running for a little bit the distance to empty recalculated but fuel economy started over.
  19. Dec 30, 2015 at 5:14 PM
    #79
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Does it register total mileage? That pretty much has to come from the engine management computer and not any backup memory. Wonder if there is backup battery for the rest of the stuff guess a test would be to disconnect the battery and see what happens. It's a new truck keep after them.
  20. Dec 30, 2015 at 5:53 PM
    #80
    swimmer
    Tucson
    2016 TRDORAC4WD
    Yes but Toyota wanted to know about the Ecco app on the Nav unit. If that does reset also it may lead them towards a software issue rather than an electrical issue.
