Resonating sound from steering column & aftermarket A/C question
Discussion in '1st Gen. Tacomas (1995-2004)' started by RichP, Feb 1, 2010.
  1. Feb 1, 2010 at 10:30 AM
    RichP
    RichP [OP] Dedicated Toyota Buyer
    Tacoma, WA
    '10 Tacoma Access Cab SR5
    Great forums - learned a LOT about the Taco. Need some help with troubleshooting a problem.
    It's a '97 Tacoma base, 2.4 w/AT on the column. I'm getting a resonating sound through the steering column when the truck is not moving - and it's most noticeable when the truck is cold. It almost sounds like something's rattling somewhere.
    If I gently tug down or push up on the steering wheel it (mostly) goes away.
    I checked the steering play and the front end bits and everything's tight.
    At first I thought it might be the shifter assembly but the Tacoma uses a cable to change gears so there goes that theory.
    Any ideas where to look next?
    Also - I'm considering getting an aftermarket A/C kit - has anyone had experience installing one of these things? I know it needs to go in for the refrigerant charge but I was hoping I could install the kit myself.
    Thanks for the help!
