Results of a Drop-In K&N air filter???
Discussion in 'New Members' started by gbrant1227, Mar 17, 2014.
  1. Mar 17, 2014 at 7:10 AM
    gbrant1227
    gbrant1227 [OP] New Member
    Garett
    Orlando, FL
    Tocoma TRD
    Just wondering if anyone had any results to post on either HP/Torque or MPG gains their getting after replacing their stock air filter w/ a K&N drop-in filter.
  2. Mar 17, 2014 at 9:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW. Only results are worse filtration. No gains in performance or mpg.
  3. Mar 17, 2014 at 9:34 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    THIS..... FOLLOWED BY MY ENGINE DYING
    K&N SUCKS
  4. Mar 17, 2014 at 12:19 PM
    Trigs
    Trigs Member
    Trevor
    98 Tacoma
    Minor lift, tires.
    Anyone run anything different? I know friends that use S&B in there domestic pickups.
  5. Mar 17, 2014 at 12:21 PM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Dirty MAF sensor.
  6. Mar 17, 2014 at 12:44 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Everyone here seems to like the afe pro dry s. Uses no oil and cleans easily.
  7. Mar 17, 2014 at 12:47 PM
    XXXX
    sKiP
    05 Prius
    and probably lets the same amount of silica into your cylinders as a K&N.
    Ill stick with OE paper filters made by Wix.
  8. Mar 17, 2014 at 12:51 PM
    Findus11
    Findus11 Well-Known Member
    Durango
    07 Taco
    leads to frickin sludge on your filter made up of dirt, bugs, sticks, and oil. Paper unless you're running your truck just on the track haha
    edit: no horsepower gains other than a rough idle from a dirty MAF sensor.
  9. Mar 17, 2014 at 2:28 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    i use OEM. switched back from K&N because of what is said above.. I wish i would have done research before i got it. The other day i was at the dealership picking up parts and i didn't realize they stock K&N products at the dealership.. I highly recommend against it. didn't have any problems with the truck till i installed it. IMO go with OEM it was designed for the truck.
  10. Mar 17, 2014 at 2:33 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Toasted turbos
  11. Mar 17, 2014 at 4:22 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Silica from what. Haven't heard of any complaints from the afe filters.
  12. Mar 17, 2014 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dirt in the air shows up as Silica in oil samples.
  13. Mar 17, 2014 at 5:38 PM
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Don't do it. Stick to everything OEM Toyota for your engine because these engines generally don't respond well to aftermarket parts and in many cases the down sides are wore than the "gains". Mine is 30k shy of 500k and all OEM parts.
  14. Mar 18, 2014 at 11:09 AM
    XXXX
    sKiP
    05 Prius
    Just sit back and wait for it.... takes a while for people to admit the failures.
    If your looking for quick data compare your MAF before and after.
    There is no way to increase airflow and filtration with a drop in filter besides adding surface volume and our OE paper filters already have twice the surface volume as a K&N or AFE. So with that said increased flow without increased surface area means additional shit in your engine.
  15. Mar 18, 2014 at 12:21 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Still waiting. :spy:
  16. Mar 18, 2014 at 12:27 PM
    XXXX
    sKiP
    05 Prius
    for what?
  17. Mar 18, 2014 at 12:32 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    lol you'll see. besides is it really worth the risk for the extra .0001 mpg that it might give you
  18. Mar 18, 2014 at 12:33 PM
    XXXX
    sKiP
    05 Prius
    what?
  19. Mar 18, 2014 at 12:36 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    you said in ur previous post just sit back and wait. I'm assuming you meant for the silica.
  20. Mar 18, 2014 at 12:37 PM
    XXXX
    sKiP
    05 Prius
    ah...ok.
    Yea, my engine is already shot so I have no need to wait.
    I actually need to stop waiting and install the new one Ive had for almost a year.
