Results of a Drop-In K&N air filter???
Discussion in 'New Members' started by gbrant1227, Mar 17, 2014.
  1. Mar 19, 2014 at 6:12 PM
    RBK51
    RBK51 Member
    Mark
    Barrie, ON. Canada
    10 Tacoma TRD Sport DC LB
    Tint, wetokole covers, weather tech mats, kenwood DNX570HD Stereo, db DRIVE S7 6 C 250 watt 6.5 component loud speakers front doors, db DRIVE S5 60 v2 350 watt 6.5 2 way rear door speakers, db DRIVE A7M 100.4 800 watt 4 channel stereo AMP under rear seat, tri fold soft tonneau cover, auto starter, Bilstien 5100's all around front @1.75, Spidertrax 1.25" spacers front and rear, K&N air filter.
    Good thing i looked it up. I was considering the k&n filter. Thanks for the info. I'll stick with oem filters.
    Whizzo likes this.
  2. Apr 3, 2014 at 7:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What do you mean by "shot"?
    Did you send your oil in to be tested?
    How long of an interval between oil changes?
    Which weight oil, which style/brand?
    How many miles on the engine?
  3. Apr 3, 2014 at 8:30 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Nope. Did the finger test. Dipped finger in oil and looks like gray metalic paint after 1500 on Mobil 1 5/30. Engines got 94k. Been knocking bad for 2k.
  4. Apr 3, 2014 at 9:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You have an XR correct?
    Did you add in the oil pan spacer, for more capacity?
    How many quarts of oil do you use to fill up, and do you use a regular sized oil filter, or a larger oil filter?
    What were the conditions when it started knocking?
  5. Oct 21, 2017 at 10:00 PM
    beverlytaco
    beverlytaco Well-Known Member
    2017 TRD off road double cab
    Got the K&N CAI for my 2017 DCOR. Big gains in MPG and acceleration. 3-4 MPG increase Had to remove it due to it not being legal in MA. Replaced it with a drop in and continue to see gains of 3MPG. Works as advertised for me.
