Resurfaced rotors at 10k service
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Christo123, Sep 13, 2018.
  1. Sep 13, 2018 at 12:29 PM
    Christo123
    Christo123 [OP] Well-Known Member
    Christopher
    Central, NJ
    2017 Tacoma 4x4 SR5-4cyl.
    So I just had my 10k service and the rotors were identified as out of tolerance so they resurfaced them.
    What is going on with quality control at Toyota??? also had a short list of smaller issues, wind noise, fog light out- never used them, Sat radio goes out at temps above 90 degrees, ac blower fan issues, etc. BTW there is a TSB out for the Fan blower motor
    AlabamaBlackSnake likes this.
  2. Sep 13, 2018 at 12:30 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    maybe they got glazed over and were vibrating
  3. Sep 13, 2018 at 1:02 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Thats funny. At my 10k service they said the bakes basically didnt look used at all.
    Flash1034 and tonered like this.
  4. Sep 13, 2018 at 1:07 PM
    BillsSR5
    bill
    2014 SR5
    u have a 2012 truck, how many miles are clocked on the brakes/truck? also I don't think Satellite radio was factory equipped in the 2nd GENS till 2014or 2015?
  5. Sep 13, 2018 at 1:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here.
    The funny part was when the SA noted that the rears were at 4mm but QUICKLY noted that that is what they are new and last forever. I agreed.
  6. Sep 13, 2018 at 1:10 PM
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
    Maybe you need to make some more cookies
  7. Sep 13, 2018 at 1:16 PM
    BillsSR5
    bill
    2014 SR5
  8. Sep 13, 2018 at 1:20 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Stop driving the truck like you stole it.
    99.9% of the time uneven pad wear on rotors (the rotors aren’t warped, its very difficult to do that on a DD) is from poor braking practices.
    cory02taco, robssol, synaps3 and 2 others like this.
  9. Sep 13, 2018 at 1:21 PM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) 33x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners
    Did you notice a vibration when braking?
    Linewalker and shakerhood like this.
  10. Sep 13, 2018 at 2:40 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I would have certainly had them replace the rotors and not turn/resurface them - if they were determined to be 'defective'. I have been through that crap with dealerships before.
    tonered likes this.
  11. Sep 13, 2018 at 2:49 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Maybe someone torqued the lug nuts with a impact tool way beyond spec
    tonered, robssol and shakerhood like this.
  12. Sep 13, 2018 at 2:56 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    How many ugga-duggas is the torque spec?
    tonered likes this.
  13. Sep 13, 2018 at 2:59 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That is a possibility, when he had his tires rotated they could have went a little overboard
    tonered likes this.
  14. Sep 13, 2018 at 2:59 PM
    Grossomotto
    2017 4WDV6LB6MT
    I’m not even sure of the torque spec, it only needs to be a little more beyond snug. Too many owners break lug nuts and strip threads.
  15. Sep 14, 2018 at 6:14 AM
    Christo123
    Christopher
    Central, NJ
    how do you know what I have? it's a 2017
  16. Sep 14, 2018 at 6:14 AM
    Christo123
    Christopher
    Central, NJ
    Yes I did
    twitchhero[QUOTED] likes this.
  17. Sep 14, 2018 at 6:17 AM
    FickleHobbyist
    FickleHobbyist Active Member
    2018 Tacoma TRD OR DCLB 4x4, Cement Gray
    Stock
    Because your flare under your username on the left side says you have a 2012. You should fix that.
  18. Sep 14, 2018 at 6:25 AM
    FickleHobbyist
    Stock
    Edit: OP deleted the post above mine - he claimed braking had nothing to do with the vibration.
    Brake pads heat up under hard braking. When you come to a stop and sit with the brakes on at a stop light, some of that hot pad material sticks to the rotor. Do this enough times and it ends up depositing more in some areas of the rotor than others. This leads to vibration when braking. I had this happen with my previous car, a 2014 Mazda 3, which I drove spiritedly.
    tonered likes this.
  19. Sep 14, 2018 at 6:31 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    So they 'identified' warped rotors? I haven't seen a shop look for things unless you complained. I hope it was done under warranty. My guess unless you drive with one foot on the gas and one on the brake, that they billed you or Toyota for unnecessary work. Unless you had a vibration in the pedal while braking, your rotors were not warped. Assuming they actually cut your rotor, they are now thinner and more susceptible to warping. Chances are unless you actually had a problem they probably did nothing more than put it on your bill.
    tonered and PackCon like this.
  20. Sep 14, 2018 at 6:39 AM
    Christo123
    Christopher
    Central, NJ
    lol of course I complained about it.... yes I had vibrations, no I don't drive the way you are "guessing", and of course Toyota paid for it as they should have. I'm not a mechanic, but I serious doubt that a persons driving habits will influence whether one has warped rotors or not, brake pad wear that's another story
