Retrax One vs. Pace Edwards Jackrabbit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by warrenroadie, Oct 26, 2013.
  1. Oct 26, 2013 at 4:29 AM
    warrenroadie
    warrenroadie [OP] Member
    Dennis
    Georgia
    2013 DCLB Prerunner Sport
    AFE Intake Cat back exhaust Leer XL
    Had my truck for two weeks now and have trying to decide which retractable bed cover is the best for me. I just want to secure toolbox and other stuff in bed. Of course I'm looking at price versus durability and known problems/issues. I would really like some input and opinions. Also if anyone has pictures of either of the covers on long bed I definitely would like to see fit on rails/side of bed. Also does this render side rails from being as tie downs? I will also be installing Pop&Lock on tailgate. I will be hauling bike just about every weekend somewhere.
    Thanks,
    Warrenroadie
  2. Oct 26, 2013 at 5:21 AM
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
  3. Oct 26, 2013 at 5:49 AM
    warrenroadie
    Dennis
    Georgia
    Thanks, I'll look at this cover.
  4. Oct 29, 2013 at 8:53 AM
    warrenroadie
    Dennis
    Georgia
    I looked at Truck Covers USA and they are little more money wise than others, appear to have good reviews on Auto Anything almost 81% 5 stars. Does anyone else have good or bad experience with Truck Covers USA?
  5. Oct 29, 2013 at 12:59 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    Retrax One
    1. Polycarbonate top - extreme cold issues, split/crack top
    2. Large canister - 11"+ square
    3. Non-assisted retract
    4. Fed-Ex ground shipped
    Pace Edwards
    1. Vinyl over aluminum slat top - better weather seal
    2. Smaller canister - 10" sguare
    3. Assisted retract
    4. FedEx ground shipped
    Truck Cover USA
    1. Powder coated aluminum top - more durable
    2. Smallest canister - 9" square
    3. Assisted retract
    4. Ships truck freight
  6. Oct 29, 2013 at 1:05 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i had the pace edwards for a few years and absolutely loved it. i had the full metal one though, no vynil. i could stand in the middle of ther cover and not worry about bending or breaking it. very well built, and offered a lot more security than the soft equivelants. it had a lock, and paired with a tailgate lock, i had waterproof, lockable storage.
  7. Oct 29, 2013 at 4:27 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I had a Pace Edwards top on my last truck (full size Dodge). It was ok and did the job, but there's a trade off. First, you have to keep the canister clean of leaves or the drain tubes will clog. That allows the canister to fill with water and rust the spring. Mine worked pretty good for about 5-6 years and then it wouldn't slide too easily. The spring finally broke around the 8 year mark and the vinyl started to lift off of the underbody around the 10 year mark. I sold the truck soon after. Snow load wasn't an issue but you couldn't stand on it. With the top and a locking tailgate, you essentially have a trunk. Don't expect it to be completely watertight and the canister will take up some room in the bed. This time I went with a tri-fold mainly due to cost but also because they come off quickly.
  8. Oct 29, 2013 at 5:28 PM
    Rokon
    Rokon Active Member
    Robert
    Arkansas
    2011 TRD OR DC - Stock
    I did a lot of research and bought a Roll'n Lock. I installed it myself to save installation. I use it continually and it works perfectly. If you do go this way be sure to have a small inspection mirror to check that the rail clips are seated properly, it's a little tricky but things work excellent if these clips fit perfect. I would do the same again if I changed trucks.
  9. Oct 30, 2013 at 1:20 PM
    warrenroadie
    Dennis
    Georgia
    Thanks for information. I'll let you know what I decide to purchase.
