retro fits?
Discussion in 'Lighting' started by jut619, Apr 18, 2012.
  1. Apr 18, 2012 at 12:47 AM
    jut619
    jut619 [OP] Active Member
    Justin
    CA
    07 PreRunner
    subs, lift, system, tires, rims
    was thinkin about changin up my headlights and gettin some retros. i wanna black out my head lights as well. could i see some pics of retros? and which ones they are? thanks guys
  2. Apr 18, 2012 at 12:54 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Theretrofitsource.com is a good place to start
  3. Apr 18, 2012 at 1:13 AM
    jut619
    Justin
    CA
    07 PreRunner
  4. Apr 18, 2012 at 4:35 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    X2
  5. Apr 18, 2012 at 9:52 PM
    jut619
    Justin
    CA
    07 PreRunner
    so would i be purchasing a complete hid kit? or would i just buy the hid projector itself?
  6. Apr 19, 2012 at 6:28 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    You'll most likely need a whole kit. Unless you have various components for it lying around that happen to all work together I would call up theretrofitsource guys. They literally have the best customer service I've personally encountered. They won't rush you, try and take you for your money or make you feel dumb. If you're worried about both cutting and money I would suggest one if the mini kits. Both the H1 and the D2S are compatible with your truck. The H1 is reportedly brighter while the D2S has a more even distribution of light from what I know. Also, something very few take into consideration is that the H1 used the mini gatling gun shrouds or one other, both of which are relatively small and won't fill out the headlight as much as the other shrouds they offer. The D2S is compatible with more and bigger ones. Fx-r is better than both but unless you're a real light enthusiast I personally don't think it'll make or break your upgrade.
    I got:
    Denso Slim Ballasts
    Philips bulbs 4300k
    D2S projectors
    Apollo shrouds
    H4/9003 harness
    Hope all this helps, lemme know if you have questions about temperature or anything
  7. Apr 21, 2012 at 9:27 PM
    VancouverTaco
    VancouverTaco Well-Known Member
    Cole
    Vancouver, BC
    08 SR5
    Billy's 5100 all 'round, 2.5 front
    Hey I dont mean to thread jack but I have a couple questions of my own, and I dont want to start another thread about retro fits.
    I have a 2008 sr5 and want to get some Morimoto mini h1's, but I'm not sure which relay and adapter and all that stuff to get. Also what is the difference between the Morimoto 3Five and the XB35 bulbs?
