Retrofit Halo Wiring
Discussion in 'Lighting' started by THE CALICO, Oct 7, 2014.
  1. Oct 7, 2014 at 9:43 AM
    THE CALICO
    THE CALICO [OP] Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Hey guys I'm going to be installing my new retrofit headlights with halos tomorrow and am curious how everyone was wiring these? I'd like for the halos to come on with my factory DRLs, but not blink with the turn signals. Any ideas?
  2. Oct 14, 2014 at 10:10 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Here is one way you could do this:
    Get an automotive relay that has the following terminals: 30, 85, 86, 87 and 87a. This is a SPDT Single Pole Double Throw relay.
    Connect it like this:
    85 (coil) to ground
    86 (coil) to +12v from the headlight circuit (or parking light circuit)
    30 (common) to a fuse connected to +12v source switched with the ignition
    87a (n.c. contact) connected to the +12v side of your halos
    Ground to the -12v side of your halos
    The way this works is: When the ignition switch is on, +12v power goes through the common terminal of the relay (30) to the normally closed contact (87a), and lights up your halos as long as the headlights are off. When you turn the headlights on, this sends +12v to the relay coil (86) which is also connected to ground (85). This causes the normally closed contact (87a) to open the circuit to the halos and turns them off.
    I hope this helps. :D
    lamber74 likes this.
  3. Oct 15, 2014 at 9:54 AM
    THE CALICO
    Colton
    Nashville
    Awesome info man thanks! Another question though, would it be possible to keep the halos on with the headlight on? Just connect 86 to another wire for the trigger?
  4. Oct 15, 2014 at 2:03 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    I was wondering about this. I thought you wanted the halos to function as DTRLs that are only on when the truck is running but the lights are off.
    If you want the halos on when the truck is running but still be able to turn them on and off, you could simply power them with a switch that would get power from an ignition circuit. You probably don't need a relay would because they don't draw very much current. You could get a switch that fits in one of the blanks on the dash. depending on what options you have there may be a blank right beside your fog light switch. By using power from a circuit that only has power when the ignition is on, you don't have to worry about leaving the switch in the on position and having the halos drain your battery down.
    If you do use a relay, you can run power to the switch , then to terminal 86. Use Terminal 87 (normally open contact) instead of 87a (normally closed contact) so the halos are on when the switch is on. In any case make sure you protect your wires with a fuse.
  5. Oct 16, 2014 at 5:28 AM
    THE CALICO
    Colton
    Nashville
    I had considered doing it that way if I couldn't figure out how to control them with the lighting stalk. I'd really like the control of the halos to remain with the stalk so it's more of factory feel. I've heard that it may be possible to tap into the DRL wire before it goes into the blinker box but I've yet to have this confirmed.
  6. Oct 18, 2014 at 8:34 AM
    THE CALICO
    Colton
    Nashville
    I get home tomorrow so I'll be able to take a closer look at the wiring. I may just connect to the ignition temporarily while I figure out the other.
  7. Oct 29, 2014 at 9:22 PM
    MTopp
    MTopp Professional bear handler
    North NJ
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Could just tap into the parking/corner lights directly or through a relay
  8. Oct 30, 2014 at 6:17 AM
    THE CALICO
    Colton
    Nashville
    Dont want to do this because I want the halos to be on during the day like my DRLs. If I tap into the DRLs they act as turn signals too.
  9. Nov 2, 2014 at 7:24 PM
    MTopp
    North NJ
    05 SR5 4x4
    Ohhh, I see. Possibly there is fuse slot you can tap and run to the relay that is always hot when ignition is turned on? if your ignition is on, so are your dtrls, right?
  10. Nov 14, 2014 at 3:24 PM
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
    What gauge wire do most people use for wiring up halos? I am wanting to wire mine to a switch in the cab so I can turn them on whenever.
  11. Nov 15, 2014 at 6:08 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Since they don't draw much power, you could use just about any size wire. However, it is probably a good idea to use at least 18 gauge or larger simply because it is stronger and won't break if you yank on it.
    christhebassman likes this.
  12. Nov 15, 2014 at 6:11 PM
    Goose8651
    DFW
    2013 Double Cab
    Thanks for the response. Will do!
  13. Nov 16, 2014 at 12:14 AM
    THE CALICO
    Colton
    Nashville
    I think mine are 14.
  14. Nov 16, 2014 at 11:28 AM
    snugz
    snugz New Member
    Jacob
    Charleston, SC
    07' TRD Off Road - CAI/Rims/Lights (So far)
    K&N CAI, Rims(too big for my taste), SpecD headlights
    Here's a link to a How to I wrote up for my install the other day. Works perfect and the results are awesome.
    http://www.tacomaworld.com/forum/lighting/351947-wiring-how.html
    Also, the DRL's on my 07' aren't the lights that go with the turn signal.
  15. Nov 22, 2014 at 8:11 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Calico since you have the '14, you can tap the parking light wires. I plan to have my halos completely separate and on switch with my demon eye light, if anyone could help with that, PLan to get an ottraw switch and use my blue sea fuse box.
  16. Apr 16, 2017 at 9:11 PM
    CG87_
    CG87_ Well-Known Member
    2015 BR DCSB PreRunner SR5 V6
    In Progress...
    Seems like the appropriate thread here so I'll give is a shot.
    My halos turn on while the car is turned off. (key out, car locked). Sometimes I catch the halos on when I walk the dog or do something outside. It's random. Sometimes it stays on for minutes and other times hours I assume when I don't catch it. My current remedy is to pull the fuse and put it back in. Anyone ever had any issues at all with this? Could this be a fuse issue or grounding issue?
    I have a 2015.
  17. Apr 17, 2017 at 11:10 AM
    THE CALICO
    Colton
    Nashville
    I'd say double check what fuse your tapped into.
  18. Apr 17, 2017 at 8:54 PM
    CG87_
    In Progress...
    I have. Everything is snug and tight. Still turns on randomly. Caught it tonight on when the car was off for over 3 hours. What could be the cause? I have it tapped on the fuel pump fuse
  19. Apr 18, 2017 at 6:47 AM
    THE CALICO
    Colton
    Nashville
    Yeah I'd try using one that's just accessory. I can't remember which one I used. I did hear something once about that happening when tapped to a certain source, but can't remember where now. Are you in the fuse box that's in the engine bay? Or in the cab?
  20. Apr 18, 2017 at 7:17 PM
    CG87_
    In Progress...
    In the engine bay. I can add pics for reference
