Retrofit projectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by tc98tacoma, Apr 12, 2012.
  1. Apr 12, 2012 at 8:12 AM
    tc98tacoma
    tc98tacoma [OP] Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    Anyone know which would be the best kit for retro fit on a first gen?
    I'm look for it to be pretty much bolt in, I don't really wanna cut my housings cause they're nice aftermarket ones, I want to run a 55watt setup but 35 is fine with me... Any info is appreciated thanks !
  2. Apr 12, 2012 at 9:24 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Morimoto mini h1 or ds2 from theretrofitsource.com. No cutting just have to sepperate the lens from the headlight housing and bolt them in.
  3. Apr 12, 2012 at 11:51 AM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    Is the light out put pretty good on them ? And can I use a 55 watt ballast and bulb?
    Anyone have pics? Either first or second gen just to get an idea of how the light output is and how they look
  4. Apr 12, 2012 at 12:16 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    They are super common around here because of their awesome output and super easy install. The H1s and DS2s are both bi-xenon so they have low & high beams. There are lots of install guides floating around TW like this: http://www.tacomaworld.com/forum/1s...00-retrofit-walkthrough-morimoto-mini-h1.html
    No need for 55w, 35w is what all OEM HIDs use and its more than enough light. Just keep the temperature 4300-6000k so you dont lose lumens to color.
    H1s:
    DS2s:
  5. Apr 12, 2012 at 12:27 PM
    Murkules
    Murkules Well-Known Member
    Dane
    Hawaii
    2016 Tacoma TRD Offroad DCSB Super White
  6. Apr 12, 2012 at 2:24 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
  7. Apr 12, 2012 at 2:34 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    55w no bueno in the Morimotos. Stick with 35w and everyone says the H1 has the best output. I am happy with my D2s ones.
  8. Apr 12, 2012 at 3:16 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I have the h1s and love them but I dont think either would disappoint. Matt from TRS has mentioned a few times that he prefers the DS2s. Guess its a preference thing.
  9. Apr 12, 2012 at 3:18 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    x2
  10. Apr 12, 2012 at 3:24 PM
    Murkules
    Dane
    Hawaii
    Whoops
  11. Apr 12, 2012 at 5:31 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    What's the reall difference between the h1s and the ds2 projectors?
    From the pics the ds2s look like a little brighter but the h1s have a nice clean line
  12. Apr 12, 2012 at 5:59 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    From Matt at TRS.com
    **On another note, those two pics are from different vehicles, installed by different guys. So it isnt exactly 100% accurate for a direct comparison.
  13. Apr 12, 2012 at 6:53 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I have the mini H1's and I love them. Check out my thread for some pictures of them installed. I have a couple pictures of the low beam output.
  14. Apr 12, 2012 at 9:02 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Hands down mini h1 is better. Trs has made huge improvements since the h1's were first introduced. Mini d2s's not so much. I've done plenty h1's and have mini d2s's now...but not for long.
  15. Apr 12, 2012 at 10:02 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Man, I REALLY want to do a retrofit...so bad haha. I have no need for them in the summer up here, so I'll have to wait till fall. Do people usually just buy a new set of headlight assemblys to do the retrofit in?
  16. Apr 12, 2012 at 10:03 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    If you have the money and want to be 1100% sure
    I didnt when I did mine
  17. Apr 12, 2012 at 10:34 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I didn't, used what I had. Good thing about the minis is they are easy to remove and reinstall if you buy new housings in the future.
  18. Apr 15, 2012 at 7:18 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    I want the halos on the projectors :/ but from what I'm hearing from y'all I'll purchase the h1's and they're cheaper so I'm not gonna complain with that !
  19. Apr 15, 2012 at 7:23 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    You can add halos to the mini h1s.
  20. Apr 15, 2012 at 7:31 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Yeah trs sells ccfl angel eyes. I used them on my retro.
