Reverse Lights Not Working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jliberatore92, Jul 14, 2014.
  1. Jul 14, 2014 at 3:08 PM
    jliberatore92
    jliberatore92 [OP] Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    Was installing some stronger bulbs in my back up lights. Put the first bulb in; it worked. put the second one in and the lights stopped working. the brake lights still work and i cant find any blown fuses.
    I was using Philips 156828 50-Watt 12-Volt GY6.35 Base T4.
    anyone have any idea what happened?
    did i melt a wire? i figured a fuse would go before that happened.
  2. Jul 14, 2014 at 3:10 PM
    Large
    Large Red
    Reverse polarity, it should fix it
  3. Jul 14, 2014 at 3:11 PM
    jliberatore92
    Troy, MI
    i already tried. no dice
  4. Jul 14, 2014 at 3:23 PM
    Large
    Large Red
    Seems to me if you plugged the first lamp in and it worked fine then the second one makes neither of them do nothing now it's a blow fuse. Did you try to plug the old lamps back in to see if they work? If the old ones worked when you removed them and they don't now I would say blown fuse? Maybe double check the fuses.
  5. Jul 14, 2014 at 3:37 PM
    jliberatore92
    Troy, MI
    The stock bulbs do not work either now. What fuse should the back up lights be on ? The tail lights are fine. And I'm pretty sure I checked every other fuse
  6. Jul 14, 2014 at 3:41 PM
    Large
    Large Red
    Did you look at the fuse box on the driver's side under the steering wheel?
  7. Jul 14, 2014 at 3:42 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    100 watts of backup lights? Still that is only about 8 amps should not have blown a fuse unless it was only 10 amp. A light bulb does not care about polarity an LED does.
  8. Jul 14, 2014 at 3:43 PM
    jliberatore92
    Troy, MI
    Yes I did
  9. Jul 14, 2014 at 3:47 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    there is a possiblity you took out a switch but it's important to test both power and grounds at the bulbs.
  10. Jul 14, 2014 at 4:34 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Dumb question? With all the checking you have been doing - do you still have the vehicle in reverse and the ign on?? If you bumped the key or the shift it could be not getting voltage....
  11. Jul 14, 2014 at 4:36 PM
    jliberatore92
    Troy, MI
    Yeah I made sure of it a bunch of times to make sure i wasnt going crazy
  12. Jul 14, 2014 at 4:43 PM
    Canufixit
    New England
    Try shutting down the ignition and waiting 15 sec and re trying???
    If no help.. Your gonna have to get a multimeter and check for 12v across the two wires at the plug. Swap the tester wires if the voltage reads negative.
    if NG then test one of the two wires to frame ground should be 12v
  13. Jul 14, 2014 at 4:46 PM
    jliberatore92
    Troy, MI
    I have done all of these things I just wanted to see if anyone had a similar problem and could tell me that I shorted 2 wires at "x" connecter. I think I'm going to have to follow the wire up to the cab. Anyone have any tips for that?
  14. Jul 14, 2014 at 4:56 PM
    Canufixit
    New England
    I'd repeat the procedure at the transmission switch...Then you know if it's before or after the trans switch.
  15. Jul 14, 2014 at 4:57 PM
    muddog67
    muddog67 Well-Known Member
    try checking the fuse box under the hood
  16. Jul 14, 2014 at 5:11 PM
    Canufixit
    New England
    On MY truck (2012) the manual says fuse 8 at the dashboard fuse box for TRAILER backup lights and Fuse 9 for IG1 Back-up lights, air conditioning system,
    shift lock system, audio system
    lo2hi likes this.
  17. Jul 14, 2014 at 5:25 PM
    Canufixit
    New England
    From another thread ... post #2
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/94979-reverse-lights-arent-working.html
    quote "Sounds like the reverse gear light sensor mounted on the transmission. Idea is when you go into reverse, the sensor gets poked and completes the circuit for the back up lights.
    On the manual, it is on the passenger side of the transmission and fairly easy to get to. Not sure where it is on the auto transmission. If you disconnect the sensor or the wiring harness from the tranny and bridge the two wire connectors, with your truck ignition in the 'run' position (not running obviously) and gear selector in reverse, you can check if the lights come on.
    Just another thought...when inspecting the wiring harness on my 2009 after delivery, noticed that the wiring to this sensor was bent almost to the point of wearing through. Not much slack on the wire. You might check this as an intermittent off/on condition.
    End Quote"
    another thread mentions that the switch is "adjustable" as the transmission pushes out a poke rod to the switch in reverse. It said that the switch was on the pass side of the manual tranny.
  18. Jul 14, 2014 at 5:28 PM
    jliberatore92
    Troy, MI
    thanks. i am kinda coming to the conclusion that the switch is the problem. and a new one is only $19 on Amazon. Prime ftw
  19. Jul 14, 2014 at 5:39 PM
    Canufixit
    New England
    Two More Thread quote ...
    From Thread http://www.tacomaworld.com/forum/2nd-gen-tacomas/94979-reverse-lights-arent-working.html post # 2 and a later post says something about a crush washer being re-moved and I assume that this means that removing the washer allows the switch to be pushed into the tranny making the switch close???
    Quote
    Sorry but I have to revive this thread. I ended up purchasing a new back-up light switch back in June. I installed it and it still didn't work. In the end I removed the crush washer and it worked fine, until this week. Same damn thing as last time, it will work intermittent. I have no clue whats going on. Has anyone tore down a 5 spd tranny and know how heavy the arm is that depresses the switch? I am afraid it is end is bending or something. Only way I can explain the odd behavior. unless coincidence got a bum switch as a replacement? Please Help!!
    end Quote
  20. Jul 14, 2014 at 8:13 PM
    jliberatore92
    Troy, MI
    So I have come to the conclusion that the switch is bad. When I shift into R (6 speed), the "beep" doesn't sound anymore. So I ordered a new one. I guess I should get new bulbs too? I mean I saw other people using 50w bulbs with no problem. Maybe with a new switch it will just blow the fuse like it should have.
