Reverse lights on in drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freshtacomaowner, Sep 26, 2019.
  1. Sep 26, 2019 at 6:50 PM
    freshtacomaowner
    freshtacomaowner [OP] Active Member
    Eric
    2007 Tacoma
    a few just starting out
    I have 2007 tacoma with automatic trans, when in drive or fourth reverse indicator in dash comes on as well as reverse lights is this something someone has encountered or is this something I need to investigate myself? when in neutral doesn't come on, only in drive or fourth. I only drive once in awhile (prolly 150 miles a month)
  2. Sep 26, 2019 at 6:55 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Your reverse switch on/in the trans is the most likely failed part. Locate it and remove it, bench test if you wish. Replace it, not that expensive, just a bit of work to get to it.
    look for the service manual page for this NOT YOUTUBE. Service manual is online, just gotta search.
  3. Sep 26, 2019 at 7:04 PM
    freshtacomaowner
    Eric
    2007 Tacoma
    I had replaced reverse switch on FORD years ago, but it didn't matter what gear always on, this threw me for a loop when goes off and only came on i drive or fourth selected, TY
  4. Sep 26, 2019 at 7:06 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Daylight driving lights on the truck?
    Might be corrosion on the trailer plug back feeding to the reverse pin on your trailer plug.
  5. Sep 26, 2019 at 7:13 PM
    freshtacomaowner
    Eric
    2007 Tacoma
    Gixerkiller you did see I have auto trans correct, all switches I found are for manual trans
  6. Sep 26, 2019 at 7:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are correct. Your issue is with the Park Neutral Safety Switch located on the passenger side of the transmission. See the below schematic for how it works for the reverse lamps.
    http://www.customtacos.com/tech.old...toyewd/06toypdf/ewd/2006/tacoma/h/em01d11.pdf
    And then this is how the same switch works for the indications on the combination meter. Scroll down to page # 5 and you will see the Park Neutral Safety Switch.
    http://www.customtacos.com/tech.old...toyewd/06toypdf/ewd/2006/tacoma/h/em01d17.pdf
  7. Sep 26, 2019 at 7:57 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  8. Sep 27, 2019 at 1:28 AM
    freshtacomaowner
    Eric
    2007 Tacoma
    makes sense as sits outside and rarely moves, that a dealer item only?
  9. Sep 27, 2019 at 2:29 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, They have them at Auto parts stores.
    Make sure to soak the collar that mounts to the shaft of the transmission with penetrating lubricate over the course of several days, it can be very hard to remove esp if you live in the frozen wasteland areas that use tons of chemicals on the road in the winter. You do not want to beat on it too much as you could damage the transmission shaft.
    See the image above how corroded it is...
  10. Sep 27, 2019 at 5:55 AM
    freshtacomaowner
    Eric
    2007 Tacoma
    TY for the pic and diagram, HOLY COW they are expensive.
  11. Sep 27, 2019 at 9:11 AM
    Gixerkiller
    Dennis
    Taylor, TX
    there is a switch that activates the lights. It kinda looks like the parking brake switch on the linkage. They go bad as it is only a momentary plunger type
  12. Sep 27, 2019 at 9:12 AM
    Gixerkiller
    Dennis
    Taylor, TX
    Go to rock auto, aftermarket are just fine for this, they should not be that expensive
  13. Jul 9, 2020 at 2:29 PM
    88Taco
    88Taco Well-Known Member
    Michigan
    Black 08 DCSB TRD Off-road.
    Rear diff breather mod. Block heater
    Adding for anyone who may visit this thread in the future. Just had this issue. Replaced the switch and the connector and it didn’t fix the problem. Ended up being that I racked my trailer light connector on a rock and snapped the pigtail. 4 of the pins were bent over on each other. Fixed that and solved my issue. Way cheaper than the switch I just bought or a wiring harness replacement.
    Lumberjackcoma and b_r_o like this.
  14. Jul 9, 2020 at 3:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You wouldn’t be the first to damage it. It’s in a “bad” location.
    Relocation might be an option?
    https://www.tacomaworld.com/threads/trailer-plug-relocation.380406/#post-10447236
    Jimmyh and b_r_o like this.
