REVIEW 3rd gen suspension on 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFergie, Apr 6, 2018.
  1. Jun 15, 2021 at 9:25 AM
    #561
    TacoFergie
    TacoFergie [OP] Well-Known Member
    Iowa
    Should be no issues, though you may want to wait till you get the leaf springs in and some time for those to settle before getting the spacer, may want more of a spacer depending on how much rake you want. Some trucks naturally will sit a little higher or lower than advertised.
    I have the Dakar Med leaf pack and they've been good for me. I haven't done a lot of looking different leaf packs but I know the Icon RXT leafs seem to be really nice for ride quality.
  2. Jun 15, 2021 at 11:09 AM
    #562
    jeffafitz
    jeffafitz Obviously, You're Not A Golfer.
    Jeff
    Northern Kentucky
    2013 TRD Sport 4x4 DCLB
    I would want little to no rake. I don't tow anything and the most I ever haul is camping gear and mountain bikes. I anticipate this setup would give me a little rake which I can live with. My other option is to go with the Deaver J66 packs which state a 1" lift, but then I'm afraid I run the chance of the front actually settling higher than the rear.
  3. Jun 15, 2021 at 11:51 AM
    #563
    TacoFergie
    Iowa
    The 1" may be a better option, only because there is a little rake even with the stock leaf springs. Being that yours are older and likely sagging you might gain 2" with the J66. I didn't run spacers with mine, but judging off others with lift blocks I'd a 1/4" (or 3/8" driver, 1/4" passenger if you expect some lean) would set you up well with the J66 packs and a 3/4"-1" would work great for the J59. But you're also getting close to needing upper control arms if you go much more than 2.5" total in the front. I'm currently skirting the fine line with my 6112's being at about 2.5"-2.75" with factory UCA's. I know aftermarket will be better, but for now its ok and aligns properly.
  4. Jun 15, 2021 at 6:28 PM
    #564
    jeffafitz
    Jeff
    Northern Kentucky
    I picked up the set today. It’s missing some pieces to make them whole unfortunately.
    First, no top hats for the front. Anyone know if they are the same as the ones on my ‘13 TRD Sport and I can just reuse those?
    Second, missing some hardware on one of the rears. Looks like one bushing, one washer, and a nut. I’m thinking I won’t be able to reuse what’s on the truck now since those components have 170k at this point. So annoying.
  5. Jun 16, 2021 at 9:43 AM
    #565
    TacoFergie
    Iowa
    Your current mounts will work on the 3rd gen without a problem.
    For the rears you can get either from Toyota, Amazon, ebay or local parts stores generally carry them as well. All you really need is the rubber portion since the washers don't really wear out. If I recall there are ones for GM trucks will work. They are somewhat a universal item.
  6. Jun 16, 2021 at 11:01 AM
    #566
    jeffafitz
    Jeff
    Northern Kentucky
    Thanks for the help. I've already ordered everything I'll need. I decided I want to go ahead and change the front shock mounts due to age, so I'm going with these KYB mounts. Hardware and bushings I found all on fleaBay.
    Also decided against the Deaver J66's. I've read some awful reviews using them with OEM shocks. Probably going with the Icon RXT's now. Once everything is here and installed I'll throw up some before and after photos.
  7. Jun 16, 2021 at 11:23 AM
    #567
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    I need to replace my rear upper bushings. Did you find a set online anywhere?
  8. Jun 16, 2021 at 11:31 AM
    #568
    jeffafitz
    Jeff
    Northern Kentucky
    I went ahead and bought a set of four on eBay. Link here
  9. Jun 17, 2021 at 12:21 PM
    #569
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    I'm looking at trying to get a set of the 3rd Gen shocks and struts for my 2007 PreRunner TRD Off-Road. I'm in dire need, as my stock suspension components have over 238,000 miles on them!
    There's a set from a 2021 for sale here right now that I've messaged the seller about, and wanted to check with you guys and make sure that nothing's changed that would preclude using these on a 2007 PreRunner.
    Also, does anyone know if the components from a 4WD will be different? I wouldn't think so, but I thought it would be wise to check with the Collective to be sure!
    One other thing: Due to the age and miles of my truck, what other components would it be prudent to replace along with the shocks and struts while I'm doing this?
    Thanks guys.
  10. Jun 17, 2021 at 12:52 PM
    #570
    TacoFergie
    Iowa
    Nothing changed with the 2021 so it will work on your truck with no issues.
    IF you have a 5 LUG wheel then it will NOT work for yours. if you have 6 lug wheels then its all good. Yours will probably end up about .25" higher than most here since it is a 2wd and there is less weight up front.
    I would check your ball joints, tie rod ends, sway bar mounts and links for being loose. Look over your leaf springs for any cracks as well, though you'd likely already be aware of this if you have clunks in the rear or one side sags more than the other in the rear. If the other guy is also selling the upper control arms and leaf springs, those would be good to grab if they are cheap. Not needed though.
  11. Jun 17, 2021 at 12:55 PM
    #571
    memphis guy
    Nashville
    Thank you very much!
    I do have the 6-lug wheels, because this is a TRDOR.
    Thanks for the tips.
    I do have a slight clunk in the rear, but I think it’s the loose bed issue that I read about here. Need to address that one of these days.
  12. Jun 17, 2021 at 8:42 PM
    #572
    memphis guy
    Nashville
    I'm excited!
    Just made a deal with @sincitytaco for a set of 2021 Tacoma TRDOR shocks and struts!
    I think this'll be a little bit of an upgrade from my OEM 2007 suspension with 238,000+ miles!
    tinker_troy and TacoFergie[OP] like this.
  13. Jun 29, 2021 at 7:49 AM
    #573
    jeffafitz
    Jeff
    Northern Kentucky
    Tomorrow is the day I throw these suckers on, but first I'm hoping you guys can help me out with a definitive answer on this. Research is making me more confused since Toyota apparently likes to switch up the colors of these dots, and it seems everyone has a different opinion on which is which. Is the RED and GREEN dots the driver's side? Seems like that's the popular opinion but I've also read that a brown dot means driver's side. My head is spinning.
    Second question, is there a way to verify that these are indeed springs from 3rd Gen TRD OR? The guy I bought them from seemed a little bit sketchy but I might just be paranoid. He had a Tacoma and two 4runners in his driveway so I want to make sure he didn’t just give me a random set of springs with 3rd Gen shocks. Since they look pretty new I gave him benefit of doubt.
  14. Jun 29, 2021 at 9:03 AM
    #574
    skimballc
    skimballc Active Member
    Shane
    ABQ, NM
    '07 Tacoma TRD OR DCSB
    Red and green is driver's side and the springs look correct. I swapped 3rd gen stuff onto my '07 over the weekend. Since you need to assemble those, use this video as reference. I disassembled mine this way to add longer studs on the top hats and put them back together very easily.
    memphis guy and TacoFergie[OP] like this.
  15. Jun 29, 2021 at 9:46 AM
    #575
    TacoFergie
    Iowa
    I need to edit and add this to the original write-up, I noticed this question has come up a few times before.
    memphis guy likes this.
  16. Jun 29, 2021 at 12:14 PM
    #576
    skimballc
    Shane
    ABQ, NM
    Flashburn075 likes this.
  17. Jul 1, 2021 at 7:08 AM
    #577
    cardinalsfan
    cardinalsfan 2022 TRDOR DCLB
    Picking up a suspension take off from a 2020 Off Road 4X4 today. Front shocks/springs, rear shocks and rear leafs for $100. My truck is a 2009 Off Road 2WD, still on original suspension, 120k miles. Hoping for a better ride and a nice 1" lift out of this.
    Couple of questions though - is it worth replacing the leaf springs? Mine were replaced with the updated ones from Toyota as part of the recall. Is there anything else worth doing while I've got it all apart? I'll have the truck until I order my 2022 and it comes in so likely less than a year.
    TacoFergie[OP] likes this.
  18. Jul 1, 2021 at 7:31 AM
    #578
    TacoFergie
    Iowa
    Since you have a 2wd you'll probably end up with a little more front lift than most of us, probably around 1.5".
    For the leaf springs. How long have you had the updated leaf springs? It probably won't be much of a change if you swap them to be honest. I haven't found any info showing a spring rate difference in the 3rd gen leaf springs. Either way, you can sell whichever leaf springs you don't use for at least $100 or more. Then your new suspension was FREE!
    cardinalsfan[QUOTED] likes this.
  19. Jul 1, 2021 at 7:42 AM
    #579
    cardinalsfan
    My leaf spring recall was done in 2016. I have a helper leaf on them from when I had a truck bed camper. If they're the same number of leafs as my current ones I might swap them out.
  20. Jul 1, 2021 at 5:45 PM
    #580
    Jkinz11
    Jkinz11 Well-Known Member
    Sk
    13 limited DC
    Just replaced my 2013 stock limited front suspension with brand new 3rd gen sport shocks and springs. Truck only has 52,000 miles on it and the stock drivers shock was leaking. It’s been a great upgrade so far. Really seems to have tightened up the handling. Tried to DIY, bolts were seized, had to take it in. Almost a cheap upgrade
