REVIEW 3rd gen suspension on 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFergie, Apr 6, 2018.
  1. Jul 16, 2019 at 7:51 AM
    #161
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    DLillest[QUOTED] likes this.
  2. Jul 16, 2019 at 8:05 AM
    #162
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    @kryten I appreciate it!
    I may be picking up a set of 2018 Sport front coils/shocks, and I was wondering if they are side specific? I noticed the OR fronts are side specific since they have different colored painted dots on the springs. But the Sport Hitachi's seem to have the same color on each side. Did you have any issues with figuring out which side is which?
  3. Jul 16, 2019 at 8:51 AM
    #163
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Can we have more specs on your truck please.
  4. Jul 16, 2019 at 10:26 AM
    #164
    05 4x4
    05 4x4 Well-Known Member
    06 access cab trdor 4x4 long bed all stock. I also have probably 200lbs of weight always in the access cab area of the truck.
    I do have airbags, which are currently not installed because I had the dealer do the new leaf springs. I’m trying to decide whether to just put them back with a pump and gauge to always monitor them, or just go with some new stiffer leafs.
    I almost wish I hadn’t added the 1/4” spacers on the front now. I’m sure it has very minimal effect, but it would have at least made some stiffening difference I assume.
    First world problems!
  5. Jul 16, 2019 at 11:35 AM
    #165
    kryten
    Canada
    I recall them being side specific. Mine had different colored dots. I had a shop put them in, but I found a thread where the colored dots were explained as to which side is which. I'll post an update if I find it again.
    I like this economical 1 inch 'lift kit' enough that I picked up a full 0 miles take off set of yellow Bilstein TRD Offroads for a change for next time around.
    These are my 2 sets. Hitachis in use now.
    Rick111 and DLillest[QUOTED] like this.
  6. Jul 16, 2019 at 11:40 AM
    #166
    05 4x4
    My 06 TRDOR was level in the front prior to the 3rd gen coil install. I opted to go with the same 1/4" spacer on both sides and it came out again even, at +1-1/4" from stock. Even though the front is 1/4" lower than the rear right now, it almost looks as if the front is a smidge higher, just due to the profile of the front I believe. Moral of the story, I didnt try to adjust for any lean. I put the red and green dot coil assembly on the drivers side, which is correct.
  7. Jul 16, 2019 at 11:54 AM
    #167
    DLillest
    Quebec, Canada
    Amazing thank you! I agree that its a great budget lift. I also purchased a 1/4" spacer for the drivers side to correct the lean.
    My current measurements (Top of tire to fender):
    Front Driver - 4.5"
    Front Passenger - 5"
    Rear Driver - 6"
    Rear Passenger - 6.25"
    I think this setup would put me pretty level all in all by adding 1.5" to drivers side and 1" to the passenger side.
  8. Jul 16, 2019 at 11:55 AM
    #168
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    What truck did the new coils come off of?
  9. Jul 16, 2019 at 11:56 AM
    #169
    kryten
    Canada
  10. Jul 16, 2019 at 11:59 AM
    #170
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Motor?
  11. Jul 16, 2019 at 12:30 PM
    #171
    05 4x4
    My motor is the v6. I believe that the trdor's were all v6? The suspension I got was from a 17 trdor.
  12. Jul 16, 2019 at 12:50 PM
    #172
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I am not sure either that is why i asked. My guess is it that there may be substantially enough weight difference between the trucks. Was the 17 an access cab also?
  13. Jul 16, 2019 at 12:54 PM
    #173
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    If the 17 is a double cab its 300lbs heavier which is a lot.
  14. Jul 16, 2019 at 1:27 PM
    #174
    05 4x4
    The 3rd gen susension I got was from a 17 double cab, however I thought they were all the same part# for the front springs? Can anyone confirm for sure? Also are the 3rd gen leafs different from the 2nd gen?
  15. Jul 21, 2019 at 9:48 AM
    #175
    05 4x4
    Any other thoughts or comments on my perdicament? I did find out(and I hope this is true) that the 16+ trd 4x4 4 door short bed is the same coil spring as the 16+trd access cab long bed... so I believe I do have the right or closest springs/suspension.
  16. Jul 21, 2019 at 1:47 PM
    #176
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Throw up some suspension pics and if there is something wrong a fresh set of eyes could help.
    tinker_troy likes this.
  17. Jul 29, 2019 at 7:37 PM
    #177
    STAGE 2
    STAGE 2 Well-Known Member
    I wonder if this would work with the fox kit that’s on the 3rd gen Pro’s
  18. Jul 30, 2019 at 12:57 PM
    #178
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Probably give 2nd gens 2 inches but it might cost a lot more because they are OEM.
  19. Aug 1, 2019 at 3:38 PM
    #179
    jimlmackjr
    jimlmackjr Well-Known Member
    JimE
    Harker height,Tx
    Toyota Tacoma TRD Pre Runner Sport Long bed
    Tacoma beast headlight Meso mods inside lights Trd pro grill Hooke road roof rack BFG KO2 Roam RTT
    I just picked up a complete set of leaf and front shock from a 2019 3rd Gen OR Billstin shock
    Right now I have 2011 Gen 2 Pre-runner TRD Sport w/4.0 with Pro Comp 2.25 Spacer kit and 1inch block
    Can I install the spacers on this 3rd Gen kit along with my Blocks on the back or will this cause to much problems with alignment.
    Right now i am at
    LF 36.5 RF 37
    LR 36 RR 36.75
  20. Aug 1, 2019 at 7:49 PM
    #180
    Roadspoke
    Roadspoke Well-Known Member
    2nd Gen Taco 4X4 AT 4.0 SBDC
    Shocks 5100, 2016 trdpro struts, K&N airfilters and removed factory maxipad in airbox, 2in. catback 50 series Flowmaster, BFG AT tires, tint, Leer shell.
    I installed 3gen 2016 front struts w/5100 series Bils. on my 09. I been very pleased with the way it drives. 5100 !
