Review Fold a cover G4 elite
Discussion in 'Product Reviews' started by CAdiveTaco, Jan 17, 2009.
  1. Jun 11, 2009 at 12:33 PM
    #101
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    You might try giving Fold-A-Cover a call and seeing if they have any ideas...
  2. Jun 18, 2009 at 4:43 PM
    #102
    Gunga
    Gunga Well-Known Member
    Glendale, AZ
    2008 TRD OffRoad DC 4x4
    Do the strikers need to be adjusted? I have no rattles on mine.
  3. Jun 19, 2009 at 10:05 AM
    #103
    mainland_newfie
    mainland_newfie Mainland Newfie
    ontario, canada
    TRD Tacoma
    skid plate, side step rails, new rims, hose clamp, 20% tint, G4 Tonneau cover, JVC 7 in double din stereo/dvd
    no idea, I had the shop install it so i whould't have thought so
  4. Jul 3, 2009 at 1:37 PM
    #104
    CAdiveTaco
    CAdiveTaco [OP] Well-Known Member
    Nor Cal
    2009 Taco DC LB Pre Runner TRD Sport
    Bed Extender, Bed matt, G4 Fold-a-cover, debadged, locked spare, taigate hoe clamp mod, TW stick
    Hey guys I'm glad to see that this write up was usefull. I wanted to let everyone know a couple of things I would change on the G4 if I could.
    1. A handle to use for actually lifting rear/front door after being unlocked. Recently it was 109 degrees out here and I need to fold up the cover to haul some gear and HOLY SHIZNET was that cover hot!
    2. I had to pick up my sons playground set from the other side of the bay, it's all lite weight plastic and packed in a huge oversize box just a little bigger than the bed and cover. the box was farly light for it's size so my intial thought was just to lay it on top of the cover. Which would have been perfect the only problem was that there was no way to tie it down with the cover closed.
    I was thinking of using a hole saw to drill 4 1.5" holes, 2 on each of the bed through the cover so that I could feed my tie downs through to the bed cleats. Then when not in use I would snap in some rubber plugs to keep it weather proof. If I can find the right plugs I think I'll do it.
    3. I like to think that I am fairly well prepared or atleast getting there in the event I have a breakdown or accident or just need to help someone out, so I have a my emergency kit/box in the back of the bed. There are a few other things I would like to carry that are failry lite weight but bulky that would fit nicely up underneath the rear door or the front door, these items would be made accessible when the doors are folded back.
    Having some small cleats of means of securing items on the underside of these two doors would be great.
    4. Similar idea as to the previous one, I wold like to mount two bike holders on the underside of the front door then once the is opened back the holders are available to secure our bikes to. The issue is here as with the previous idea is drill through the cover as well as being able to secure the door in its folded position.
    I'll keep researching for the plugs and hardware, hopefully I'll come up with something.
    Have a Great July 4th!
  5. Jul 3, 2009 at 2:18 PM
    #105
    mainland_newfie
    ontario, canada
    TRD Tacoma
    does anyone have a g4 that rattles, not sure everything seems tight but it squeaks while driving.
  6. Jul 9, 2009 at 7:20 AM
    #106
    Gunga
    Glendale, AZ
    Are you not mechanically inclined at all? You can download the install instructions if you don't have them. Try adjusting your striker pins down further. Or just go thru and make sure all the bolts are tight. It's not rocket science.
  7. Jul 9, 2009 at 8:45 AM
    #107
    truckalter
    Luke
    Waynesville, NC
    Its not rocket science...
    BUT... he had a shop install it and I assume paid for such... Its their job to take care of it for him... They need to do their job to his satisfaction.
  8. Jul 9, 2009 at 10:02 AM
    #108
    Gunga
    Glendale, AZ
    I understand that but why take the time to go back to a shop that might not be close by to do something yourself in 10 minutes.
  9. Jul 14, 2009 at 10:51 AM
    #109
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    How did i missed this thread, this g4 looks awesome!
  10. Aug 10, 2009 at 5:41 PM
    #110
    jsrsxtypes
    jsrsxtypes Member
    High Point, NC
    I heard that Fold-a-cover had some packaging problems in the past. Just want to know if they are currently doing a better job of padding the cover inside the box?
  11. Aug 11, 2009 at 8:31 AM
    #111
    Gunga
    Glendale, AZ
    As I recall, mine was packed pretty well. No damage.
  12. Aug 11, 2009 at 1:45 PM
    #112
    jsrsxtypes
    jsrsxtypes Member
    High Point, NC
  13. Aug 13, 2009 at 4:45 AM
    #113
    Tacoma4Life
    Tacoma4Life Member
    Pennsylvania
    2010 4cyl W/Access Cab
    That Looks great and sounds the best because you cnt cut into it and you can lock it, but one question.. Do you remember what the shipping weight was for it it looks fairly heavy overall I have a v4 and would like to keep mileage down with as least weight as possible.
  14. Aug 14, 2009 at 11:58 AM
    #114
    jsrsxtypes
    jsrsxtypes Member
    High Point, NC
    I am guessing around 60 to 75 lbs
  15. Aug 14, 2009 at 2:24 PM
    #115
    Gunga
    Glendale, AZ
    60 lbs. is probably a good guess. I think it came UPS. I really like this cover. The quality is very good.
  16. Aug 15, 2009 at 10:27 AM
    #116
    Tacoma4Life
    Tacoma4Life Member
    Pennsylvania
    I dont suppose you could still mount a ladder rack on this one?
  17. Sep 4, 2009 at 12:52 PM
    #117
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I have had my G4 on for 3 weeks now. Best cover I have ever had. I keep tools in the bed or my truck and misc. other stuff. I wanted the locking tailgate so I have that now. No rattles and it might leak some water but I am in Texas and it has not rained here for a while. I have a bed mat in the truck so most of the time the floor should stay dry.
    I had the rubber piece between the tailgate and the cover pull loose. I called the G4 office and they are sending me a new one. In the mean time, I used some Grollia glue and it is holding.
  18. Sep 14, 2009 at 10:07 PM
    #118
    thomasr1950
    thomasr1950 19 Tacoma TRD Off Road
    central us
    What are the pros & cons of each of these? It looks like he G4 will open from behind the cab vs the Flip Bak opens rear to front. The G4 appears to sit just above the bed, the Flip Bak sits down a little below the bed. Both are pretty close in price and look like the installation is similar. I'm looking into buying a cover for my Taco & would like some feedback on both of these from people who have bought them.
  19. Sep 25, 2009 at 10:54 AM
    #119
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    sorry just confirming.... if you get a G4 you can lock the tail gate then close the cover and the bed is secure or do you need to get a locking tail gate as well?
  20. Sep 28, 2009 at 10:12 AM
    #120
    Gunga
    Glendale, AZ
    There is a tab that locks the tailgate when you lock the last section but you have to drill into the tailgate and install a loop. I got the pop n' lock so I didn't have to drill holes in the tailgate.
