Revos 2 psi question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Dec 21, 2011.
  1. Dec 21, 2011 at 8:59 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi guys just got installed a set of Bridgstone Revo 2 265/75/16. My question is what psi do you recommend to run I currently have them a 36 psi all around. What do you suggest??
  2. Dec 21, 2011 at 9:00 PM
    Hektor
    Texas
  3. Dec 21, 2011 at 9:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Google "Chalk Method". Every truck is different weight wise, so the best way is to use that.
  4. Dec 21, 2011 at 9:19 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Check the stickies in this section for a method of determining what psi works best for your truck/tire combo
  5. Dec 22, 2011 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I just got a set of Revo 2's back in July. I run them about 32-34psi.
    That's the same pressure as I ran in my original tires (Dueler H/T's).
    For me personally, 32psi is nice. If you get much higher than that, the ride gets a bit harsh.
  6. Dec 22, 2011 at 8:38 AM
    bobg03
    bobg03 Well-Known Member
    NE Ct
    Tacoma
    Wheels, Bull Bar, Tonneau Cover
    I got em at 36, rides pretty nice, and I will say 100% better than the Dunlops did at any pressure....
  7. Dec 22, 2011 at 12:43 PM
    Hektor
    Texas
    P or Lt??
  8. Dec 22, 2011 at 9:22 PM
    Hektor
    Texas
    Hi guys I just got a set of Bridgstone Revo 2 P265 75 16. Just wondering what PSI are you guys runnin on Revos 2 P rated with the size above. Thanks in advance guys.
  9. Dec 22, 2011 at 11:23 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Put in whatever is recommended on your door jam. If you don't like the way it rides, you can adjust up or down from there.
  10. Dec 23, 2011 at 7:43 PM
    Hektor
    Texas
    Bump anyone else??
  11. Dec 24, 2011 at 3:33 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  12. Dec 24, 2011 at 3:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  13. Dec 25, 2011 at 7:23 AM
    Janster
    Jandy
    Lancaster, PA
    P rated Dueler Revo 2's??
  14. Dec 25, 2011 at 7:46 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
  15. Dec 25, 2011 at 7:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This is the WRONG answer. That pressure is only good for the OEM tires and original size. It may be close or even the same-but that is a fluke. Chalk test everytime...
  16. Dec 25, 2011 at 8:35 AM
    Janster
    Jandy
    Lancaster, PA
  17. Dec 25, 2011 at 9:18 AM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
  18. Dec 25, 2011 at 10:10 AM
    bobg03
    NE Ct
    Tacoma
    P....I see no reason (at least for myself) to have an LT..Max press on the P is 44..and LT in a C rating would be 50.
    I had the same size on a Cheby w/a 7200GVW in a C rating that I towed a 6K pound boat w/and the sweet spot was 43.
    If I needed an LT....I'd have a bigger truck, but I'm older and live in a condo now so I downsized and am happy...:D
