Revtek 3" / 1.5" AAL Lift Kit
Discussion in 'Suspension' started by BlkTaco47, Nov 2, 2016.
  1. Nov 2, 2016 at 2:31 AM
    BlkTaco47
    BlkTaco47 [OP] Unhinged
    2016 Black AT DCSB 4x4 TRD SPORT
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Sub Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Starter TRD Pro Grille ROAV Dash Cam 3" RC Lift Turn-down exhaust pipe TRD PRO Shift Knob vF Tune
    I'm looking to put a 3" lift on and wondering if I should go
    with a block or a AAL in the rear.
    Will 3" in the front and a 1.5" in the rear keep it level?
  2. Nov 2, 2016 at 5:21 AM
    BlkTaco47
  3. Mar 26, 2017 at 5:03 PM
    effin_guido1226
    effin_guido1226 IG: effin_guido
    Matthew
    San Antonio, TX
    2016 Tacoma TRD Sport 4X4
    - N-FAB RSP front bumper - 3" Bilstein 5100 coil over & suspension up front - LR UCA's - OME AAL & suspension in back -Ion Alloys & 285's to sit on - Trail Gear Sliders welded to frame - Rago Bed bars & hilift
    I am about to get the same done.... what did you end up doing? looks like no one responded.
  4. Mar 26, 2017 at 7:32 PM
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    Stay away from blocks and spacers. Go with AAL and springs
  5. Mar 26, 2017 at 8:14 PM
    effin_guido1226
    Matthew
    San Antonio, TX
    So you went with the last option you posted. The one including shocks for the extra $40
  6. Mar 26, 2017 at 8:23 PM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    That kit is still trash. Why spend over $30k on a truck and buy junk for it?
    Most people on this forum with recommend bilstein 5100 all around. Most lift with 887 springs (2 inch lift) or 888 springs (3 inch lift)
    http://www.headstrongoffroad.com/store/p401/Coil/Bilstein_5100_Kit_(HS16BK-1).html
    $643 to lift it with actual shocks and struts if you don't purchase UCA
  7. Mar 26, 2017 at 8:28 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Don't use blocks and spacers. Leave the overload in with 1.5" progressive AAL you can get 2". Once you start going into 2.5" and more you are inviting issues.....
    Matic likes this.
  8. Mar 26, 2017 at 9:00 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    SOLD 16' BROcelona SRAC4x4
    Stock
    Front, I'd go with 3rd gen 5100's and keep the factory springs. Rear, 3 leaf add-a-leaf with 1/2" lean spacer and 5100's.
  9. Mar 26, 2017 at 9:26 PM
    smitty99
    Scottsdale
    taco lean spacer is usually 1/4" and does not go in the rear but on the front coil/spring? or.....?
  10. Mar 26, 2017 at 9:39 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    My rear is over an inch to the left :angrygirl: front is dead even since I added a 1/4" spacer. Rear is still over 3/4" off even with the 1/2" shim/ spacer. Frustrating to say the least.
  11. Mar 26, 2017 at 9:40 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2017 Tacoma DCSB TRDOR MT 4WD OMG WTF LOL
    What about for 2" in front and 1" in rear?
    5100's up front?
    Is there an AAL that'll get me 1" in rear, or would a 1" block be acceptable? The only AAL's I'm seeing are 2".
  12. Mar 26, 2017 at 9:44 PM
    smitty99
    Scottsdale
    If you want level I'd max out the 6112s (5th notch passenger side 6th notch driver side) then 1.5" AAL in rear. If you do 2 inches in front and only 1 inch in rear I think you may have a slight " bro rake" (front end high)
  13. Mar 26, 2017 at 9:53 PM
    BlakeM
    Blake
    Gonzales, LA
    Yeah, I definitely don't want the front end high.
  14. Mar 27, 2017 at 5:35 AM
    effin_guido1226
    Matthew
    San Antonio, TX
    Hey Notony,
    I can purchase that kit that you added the link for and it is ready to be installed? theres nothing else i will need to purchase with that? sorry for all the questions i am very new at this and want to make sure i do it right the first time. a 3'' lift is all i want on my truck, dont really see myself going any higher.
    If i purchase this kit from the link and show up to a local shop, they wont have to add anything to this correct? just charge me for install and alignment.
    thanks,
  15. Mar 27, 2017 at 10:55 AM
    Tx_Taco
    Tx_Taco Well-Known Member
    Rick
    17 TRD OFF-ROAD 4x4
    That's correct I ordered this kit with 888 springs doing my install this week if you wanna see it on a truck in person
    effin_guido1226 likes this.
  16. Mar 27, 2017 at 11:50 AM
    BlkTaco47
    I ended up not doing anything. kept reading so many vibe and other issues I said fuk-it
    for right now as it's my daily driver so I have no desire or time for any issues that may
    arise from a lift.
  17. Mar 27, 2017 at 12:11 PM
    effin_guido1226
    Matthew
    San Antonio, TX
    @blkbelt42 hahaha damn ok
    well i might see what @Tx_Taco has going on and from there make my decision and find a shop to install.
  18. Mar 27, 2017 at 7:33 PM
    effin_guido1226
    Matthew
    San Antonio, TX
    I ordered it today. I went with the 888 spring. LR UCA's. Strut assembly. And AAL in the back.
    Should be getting a local shop here to install it next week. What's a fair rate for a shop to charge for install? One shop I talked to charges $89/hr
  19. Mar 27, 2017 at 8:20 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    18' Silverado
    None
    Grab a floor jack and some beer. ECGS is the only painful part.
  20. Mar 27, 2017 at 8:24 PM
    smitty99
    Scottsdale
    You're going to need an ECGS bushing to fix the needle bearing which will fail sooner than later and you'll be driving down the road chewing up your driver side axle which will cost a ton more to.fix down the road.
